lt1 intake manifold
And just how much does a set up like that go for?
Also What point in mods is an intake like that even justified on the the car. HP ratings etc.
Thanks
I wouldn't suggest a single plane for a NA car making under 450 hp or so. Unless they are looking to improve high rpm power at the expense of low end torque.
A ported LT1 intake can support upwards of 500hp before it becomes a huge restriction on a non forced induction application.
To the OP's request If you are still on stock heads I would just replace the intake gaskets and insure you have the lifter valley sealed when you replace them. The key is dropping the intake straight down and not sliding it back and forth before bolting it down.
I agree!
