4L60E to T400 swap
94Z
LT1
383 Stroker
4:10 rears
30# SVO injectors
58mm BBK (w/ ported intake)
CAI
Head & Cam package to come
it was really easy. the new trans will bolt up no problem. you'll need a new stall tho. you can fab up a trans mount or purchase one. i used the stock driveshaft tho. i got a th350 with the longer tail.
If it is a driver, no OD, no lockup, blows in a big way, the no OD may not be that ig a deal alone, but combine it with no lockup and the fact no lockup will make you pick stall concervatively and you will quickly realize the three speed swaps are best left to track cars.
The 4L60E can be built to hand pretty serious power, only problem is finding someone competent to build it. The 4L60E gets a bad reputation because there are more incopent fools building it than there are good shops, and the incompetent guys tend to blame the design rather than learn from their mistakes.
For a drag car only or something running lots of NOS and well in the 10's . . . . a TH 350/400 can be justified. Anything less and a "properly built" 4L60 can handle the abuse while giving you a better launch (due to lower 1st gear) and you still have OD and the lock up feature so RPM on the highway can be 2400 RPM @ 65 MPH as opposed to 3500 RPM with a TH 350 (no overdrive), 3600 stall and no lock up feature (both based on 4.11 gears and 26" tires).
My 3760 lb car has ran lots of 11.30's 1/4 mile and 7.20's 1/8 mile (11.21 and 7.13 best ET's) with 3.42 gears and "built" 4L60 from Cahall Performance Transmission and never had a problem.
No shifter installation problems, no driveshaft change, no TQ arm relocation problems, no brackets/mounts to buy/make. Just plug-n-play.
Really depends on the goals of the set up but make sure and consider all options before just throwing a TH 350/400 in because "someone else" said you need one and could not get "their" 4L60 to last. TH 350/400 IS the right answer for some but alot of people would be happier with a 4L60 if built by the right person/shop.
Lloyd
Make sure and get some eferences and talk to the people running his transmissions in 10 and 11 second cars with no problems. Everyone will claim they can do it but not as many can accomplish this and have the trans last.
Even if he offers a $$$ back guarantee or repairs for free, I would rather not have to pull and stab the trans a cpl of times while he figures out what he is doing wrong or blames it on the tune. Figure is getting stranded at the track or on the street with wrecker fees, wrecker scratching, scraping bumpers while towing, etc, all for a lil $$$ save on a trans build.
You could be left with a ruined converter even if he gives your $$$ back on the trans and a lot of hours invested in R/R of thrannys. Not much fun at all.
I have no idea who you are using or what they do, just make sure they CAN build a good trans by listening to people that are running them in cars equal to yours as far as weight/ET. Also ask if he ever had to pull/adjust anything or just install and go.
This might save you some $$$ or you might have found one of the few people that can build a good 4L60 at a good price. Most people that have this ability know what it is worth and are charging for there skills. Some are chaging the same price and STILL can't build one correctly.
Just do lots of research and maybe it will save you some $$$.
Lloyd
It was cheaper then buying a new input and out put shaft to continue running nines with the 4L60E
That being said we do have nine second cars running on 4L60Es. When built properly they work just fine
