cc306 question
Old Jul 31, 2008 | 11:52 PM
Untouchable9262's Avatar
Default cc306 question
since the cc306 is a 510intake lift and 540exhaust lift, should i run 1.6rr on intake and 1.5rr on the exhaust, someone was tellin me this would even out the intake/exhaust output. any advice?
Old Aug 1, 2008 | 01:13 AM
LM97Z's Avatar
Your intake valve is always bigger, so you'll be more even with the same size rocker on both. now it also depends on the cams overall profile, not just the lift.
Old Aug 1, 2008 | 01:26 AM
BOLO's Avatar
The 306 has been proven again and again for performance as an off the shelf cam. The duration, lifts, and lobe separations were designed for a purpose by Comp Cams. Do a search, and you'll find many satisfied users of this cam.
Old Aug 1, 2008 | 11:06 AM
Chevyguy358's Avatar
1.6rrs on both...i believe the exhaust lift is higher to help with scavanging
Old Aug 1, 2008 | 12:05 PM
LT1MAN's Avatar
very happy 306 user here
