? on LT1 ATI damper
Old Aug 3, 2008 | 12:24 PM
96silverram's Avatar
Default ? on LT1 ATI damper
Just wondering if there is anything special that has to be done when installing the ATI damper on a 96 LT1 ? I'm hoping its as simple as remove stock damper and re-install ATI super damper Also, should I replace the crank bolt with something like an ARP. If so, does anyone know the part # for the ARP crank-bolt ?
Old Aug 3, 2008 | 02:34 PM
BALLSS's Avatar
I used the bolt than came with the ATI. The ATI unit is "keyed" and I can't remember if it came with one. You can pick one up at auto parts store.
Use a hub removal/install tool.
Old Aug 3, 2008 | 03:28 PM
Mr.Whitey's Avatar
Mike - I just applied some nevrseize and used an install tool, it was simple. ARP offers two bolts that you could use - 134-2501 or 234-2501.
Old Aug 3, 2008 | 05:12 PM
cnorton's Avatar
Be very careful to double check the length of the standard ARP bolt relative to the depth of the threads in the LT1 crank. I've run into a couple that were two or three threads too long (or the crank lacked a couple of threads). It's so close you that might not notice that you've bottomed out but you lose the clamping effect and run the risk of problems with the threads. Just grind a little off the end and the problem is solved.
Old Aug 4, 2008 | 11:36 AM
Whitey,
Wow, long time no see ! What have you been up to ? Thanks for the ARP part #'s. Is there a reason for using one over the other, it looks like the 234-2501 uses a larger head.
Cnorton,
Thanks for the FYI tip on the thread length.
I just spoke with ATI, they gave me the suggested range on the mic'ing the crank: 1.2450 to 1.2454 (suggested range of stock crank diameter). The tech also said, tolerance of .0008 + or - from that range would be acceptable for a press fit. They recommended putting loc-tite on the crank when I press fit the unit, what do you guys think ? If so, assuming the (RED) loctite.
Old Aug 4, 2008 | 01:46 PM
Mr.Whitey's Avatar
Whitey,
I've been trying to get my car to like me again after a new engine....been some "bumps" along the way.
Here are some relatively new pics.
I used the smaller size bolt, but for no particular reason. The socket size is the only difference between the two bolts.
Old Aug 4, 2008 | 02:21 PM
WHITEBOY_ZACH's Avatar
I Got A Hub For The Ati Damper ..for The F Body If You Need It....mines Goin On A B Body, But Came Off An F Body....so I Need To Buy The Longer B Body Hub.
Old Aug 4, 2008 | 02:38 PM
After looking at your new pics, I feel Your stuff just looks better, better everytime I see your car. Thanks for the info on the crank bolt. Do you have a suggestion on any particular color of loctite for the crank and damper ?
Old Aug 4, 2008 | 03:12 PM
Mr.Whitey's Avatar
Thanks! It's funny that seeing pictures of my car makes you feel ...because it makes me feel the same way in person.
Antiseize is all that I used on the crank. I did use Loctite on the bolts. IIRC, I used blue on the crank bolt and red on the smaller bolts around the damper. I've read some threads from people having trouble keeping the ARP bolts from backing out...so red might be a good idea...but it could also be a real PIA to remove in the future. You might want to double check with ATI on which color to use.
Old Aug 4, 2008 | 08:26 PM
cnorton's Avatar
I've never had a problem with the crank bolt. Wouldn't know what to advise although it's hard to imagine a properly torqued ARP bolt coming loose. ATI recommends loc-tite on the countersunk cap screws holding the dampner to the hub. The torque spec on those capscrews is relatively minimal.
Good luck.
Old Aug 4, 2008 | 08:32 PM
Thank you
Old Aug 4, 2008 | 09:22 PM
Evaporate's Avatar
Simply amazing on the underhood pics. That should win shows right there.
Old Aug 4, 2008 | 09:28 PM
95zpro's Avatar
ditto, those underhood pics are sic ! Nice attention to detail...
