Wiper Blades--SERIOUSLY?
Old Aug 4, 2008 | 12:31 AM
Dendyc's Avatar
Default Wiper Blades--SERIOUSLY?
Wow this one pissed me off---just went to wal-mart to get wiper blades...the 24inch anco straight blade was fine on the driver side, albeit a little loose on the j clip. However, the passenger side blade didn't even touch the windshield. Took it back and went to auto zone, they told me that I needed a curved blade, fine--I bought the $20 rain-x curved blade. Still no fit. Returned it and they told me that I needed to get the Anco specialty blade that was made to fit the car--then told me they didn't carry them anymore. Great! You'd think they could at least use a standard wiper blade. Looked online and they want 28 bucks for one shipped?
Do any of the other chains carry the blades still?
Old Aug 4, 2008 | 12:58 AM
Bowtie Boy's Avatar
One of my blades doesnt hit either...funny. I am about to just take them off I dont drive it in the rain anways.
Old Aug 4, 2008 | 01:03 AM
daniel6718's Avatar
bend the blade...but actually i think its the springs in the wipre arm loosing its tension...common problem with lt1 cars
Old Aug 4, 2008 | 01:09 AM
Bowtie Boy's Avatar
You dont like LS1s much do ya dan?
Old Aug 4, 2008 | 01:29 AM
daniel6718's Avatar
ls1 cars? ya i love them...just too expensive for me...
Old Aug 4, 2008 | 06:46 AM
Mattsz28's Avatar
Pepboys (may be a northeast thing) has them at my local one sitting on the shelf. They say "24in CAMARO" on them.
Old Aug 4, 2008 | 06:55 AM
blackz6sp's Avatar
Anco part# 22-24 the j-hook is upside down on the f-body, it takes a special blade.
Old Aug 4, 2008 | 08:14 AM
Purple95Z28's Avatar
I noticed the wiper arm tension in my arms are loose now also (resulting in the blades not touching the windshield completely (especially the lower left corner of the windshield). Is it possible to fix the spring in the arms or whatever or does GM even sell new ones anymore (or any aftermarket companies?)
Old Aug 4, 2008 | 08:37 AM
Paul Bell's Avatar
That's MISTER MODERATOR
I changed my arms over to LS style, with the "correct" J-hook and installed Bosch Icon blades (not available for the inverted J-hook of the LT years). I went shorter on the right side. Very happy windshield in the rain.
Old Aug 4, 2008 | 08:40 AM
HoLLo's Avatar
Yeah both of my blades seem to lift up about half way up the windshield and totally miss this spot thats like 2 ft x 2ft
Old Aug 4, 2008 | 08:43 AM
3800RS's Avatar
if you have a 93-97 and your blade misses the window you have the wrong blades. Our cars have the upside down hook and only takes 1 special type of 24". Your basic 24" blade wont work.
Old Aug 4, 2008 | 09:14 AM
I definitely have the right blades, but if you look at the base of the wiper arm its not holding down tension on the windshield like it should
Old Aug 4, 2008 | 10:36 AM
landstuhltaylor's Avatar
I got my replacement wiper arms and blades through Autozone. They work fine, but there is a section about 6"x4" that it completely misses on the bottom left.
Old Aug 4, 2008 | 12:49 PM
sweet-94z28's Avatar
I bought Michelin brand standards and i bent the metal blade frame. Works perfect minus the fact that the rubber noise bushings on the wiper motor are now shot and the motor slaps around in the firewall making all kinds of noise.
Old Aug 4, 2008 | 01:22 PM
fergymoto's Avatar
Go to a GM dealer and get a new set of blades then just get refills for them whenever the rubbers go bad. They will work perfect and cost around $50 for two
Old Aug 4, 2008 | 04:20 PM
djjab57's Avatar
have to get the anco slim ones, had the same prob tell i got those the fit great i cant remember if i got them at oreily or az .
Old Aug 4, 2008 | 04:38 PM
djjab57's Avatar
i remember now they are anco n24 narrow fit perfect but like already said i dont drive in the rain either ???
Old Aug 4, 2008 | 05:05 PM
hyperzone's Avatar
I think I was confused by the blades last time I switched but, didn't even think twice.. just bent them a bit and was in business. Never knew wiper blades could be so complicated. hahaa...
Old Aug 4, 2008 | 05:58 PM
leadfoot4's Avatar
I just get the "refills".....It's been a while, but I think Bosch makes them.
Old Aug 4, 2008 | 06:16 PM
97Z28LT1's Avatar
That's what I did and no problems here. If I remember right, they were $8 or $9 each.
