Benefits of a lt4 knock module
Old Aug 5, 2008 | 12:12 AM
10.5LT1's Avatar
Default Benefits of a lt4 knock module
What are some of the benefits of running the LT4 knock module?
Old Aug 5, 2008 | 12:56 AM
LSWHO's Avatar
Less timing pulled due to false knock = more hp.
Old Aug 5, 2008 | 09:40 AM
10.5LT1's Avatar
is it on both OBDI AND OBDII?
Old Aug 5, 2008 | 11:48 AM
Stroked96Bowtie's Avatar
Both computers can use the same chip...I converted from an OBDII to the OBDI and used the same module.
Old Aug 5, 2008 | 11:59 AM
kinglt-1's Avatar
Originally Posted by Stroked96Bowtie
10-4
I have had issues with the 0bd-1 computer reading obd-2 knock sensors and vise versa. The knock module itself will work with both.
Old Aug 5, 2008 | 01:07 PM
bobdec's Avatar
The lt4 KM will only help if you are experiencing spark retard due to false knock. Otherwise no benefit will be seen.
Old Aug 5, 2008 | 01:21 PM
Bowtie Boy's Avatar
Is there any case where people will always pull timing? Like with headers or what.
Old Aug 5, 2008 | 02:16 PM
OEM_TA's Avatar
Most commonly stated causes of false knock are roller rockers and headers.
Like bobdec stated unless you are experiencing timing being pulled by false knock there is no benefit to having the LT4 KM. However since they are cheap and easy to install they are not a bad addition to most cars.
Old Aug 5, 2008 | 11:27 PM
IronOutlaw's Avatar
IT helped with my high rpm miss after i installed my headers.
Old Aug 5, 2008 | 11:38 PM
LT1's Avatar
LT1
Dont install LT4KM if you run nitrous. It will prevent enough timing retard.
Old Aug 6, 2008 | 03:02 AM
tspence45's Avatar
It'll help with a bad exhaust leak too. I have one on the passenger side emissions fitting and it would cause my car to bog out a little when I first got it. The next week I got my LT4KM and haven't had the problem since.
Old Aug 6, 2008 | 09:23 AM
camar0corey's Avatar
I'd never heard of this. Shouldn't you be pulling timing out of the tune anyway? If your going to spray and let it knock and pull timing that way, I think its too late.
