oil coming from open header, bad?
Old Aug 8, 2008 | 01:42 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
Default oil coming from open header, bad?
My car's been sitting for a while b/c it has a bad opti ( atleast I think ) and I started it up today to move it into the garage, it sat there all day, and when I started it and moved it back to its spot, I noticed that there was sludgy oil on the ground from the header, and its blown on the underside of the car a little, drivers side only... Valve seal's?
Old Aug 8, 2008 | 01:46 PM
the_merv's Avatar
Veteran: Air Force
Possibly.. more than likely from it sitting for a while and the Seals shrunk a little bit. When it warms up it should go away..
Old Aug 8, 2008 | 01:49 PM
Fixxer99TA's Avatar
X2, get that thing heat cycled a few times when its fixed.........
If it still does it after using it a few times, then theres something that needs to be found.
Old Aug 8, 2008 | 01:58 PM
the_merv's Avatar
Veteran: Air Force
My Stroker does it when it's warming up.. expecially when it's cold out and I haven't driven it in a while. First time I noticed it was when it was parked in the Garage, back of it against the wall, and there were little black specs all over the white wall.
It took a min to clean it..
Old Aug 8, 2008 | 02:04 PM
daniel6718's Avatar
hmmm never heard of that at all...i dont se how the seats could shrink???
you positive it was oil and not water mixed with the carbon in the headers....
Old Aug 8, 2008 | 02:12 PM
the_merv's Avatar
Veteran: Air Force
That's what I thought at first, and it was really slimy/oily.
Could be Carbon and Water mixed.. but it seemed like Oil more than anything..cause it goes away when it's warmed up.
Old Aug 8, 2008 | 06:11 PM
Sgt. Spuds's Avatar
It might have been a combo of water gas and carbon, as its running super rich right now... But it was really slimy and sludgy
Old Aug 8, 2008 | 07:11 PM
Fixxer99TA's Avatar
It would be running super rich if you had a bad opti for awhile too, would cause lots of misfires which would equal exactly what your seeing........A sloppy fuel mess running down your headers.
