*PICS* Lt1 Hsr Design
Old Aug 9, 2008 | 03:25 PM
GGPC's Avatar
Default *PICS* Lt1 Hsr Design
These are pics of the mule we've been working on. This particular intake has no port work. It is the design we will work off of. The final product will look a little different. *PICS* Lt1 Hsr Design-1.jpg
This is the plenum with the bolt provisions removed. It really opens it up.
Just showing you the height difference between the two.
Example of how the runners change shape which is key to better #s
We took a lot of extra aluminum off to make this a true air gap. There is a good amount of welding involved but I think we have it down to a science now.
We were going to paint it but you cant see the welding detail when it is.
The area in the front where the thermostat sits can be taken off. But it will cost extra $. We will have to cut it off then machine it down. I guess we can leave that as a option.
Old Aug 9, 2008 | 03:40 PM
AChotrod's Avatar
looks pretty good! How long untill they hit production?
Old Aug 9, 2008 | 03:43 PM
GGPC's Avatar
Not sure. We have some other tests to run first. Soon as we can get the L98 versions done with for some customers we will know for sure.
Old Aug 9, 2008 | 03:47 PM
Fixxer99TA's Avatar
Oh man that looks hawt, I cant wait for some initial #s from the test runs. If it all looks good, this might be going on this winter along with some LE2 or LE3s...
Im pretty much sold as long as it gains something (and we know it will).
Old Aug 9, 2008 | 05:28 PM
I8ASaleen's Avatar
How about hood clearance?
Old Aug 9, 2008 | 05:43 PM
buffman's Avatar
are the new intakes going to have provisions for those who still want PCV valves??? Any ideas on cost?
Old Aug 9, 2008 | 05:57 PM
LS1 Eddie's Avatar
I could certainly understand the hood clearance but what about the fitment of the rest of the equipment such as the elbow and air intake?
Old Aug 9, 2008 | 06:02 PM
GGPC's Avatar
There will be no issue with hood clearance.
Old Aug 9, 2008 | 06:08 PM
GGPC's Avatar
Yes, there will be provisions for PCV valves. Not sure on costs. We may get discounts for ordering XX amount of HSRs and with the new plasma cutter, it will also shave some time off the job.
Old Aug 9, 2008 | 06:10 PM
GGPC's Avatar
The elbow will fit fine. Now is the air intake filter inside of a housing?
Old Aug 9, 2008 | 06:47 PM
Pro_built7's Avatar
ya, for instance my k&n goes down into a housing/box in the fender in front of the dr.side tire completely enclosed
Old Aug 9, 2008 | 06:48 PM
Pro_built7's Avatar
I can't wait to see how this intake does
Old Aug 9, 2008 | 07:50 PM
O Holy P's Avatar
I'd be down for it. +1
Old Aug 9, 2008 | 08:25 PM
buffman's Avatar
GGPC you said these were going to be custom tailored for applications correct? So if one of us B-cars wanted to buy one, we could potentially have a longer runners/larger plenum(sp)/etc since we have more hood clearance?
Old Aug 9, 2008 | 08:45 PM
GGPC's Avatar
That is correct. We will leave the runners as long as humanly possible.
Old Aug 9, 2008 | 09:46 PM
Orr89rocz's Avatar
very nice, i got the regular HSR on my 383 and so far its running pretty good. Cam is only 230 degrees on the intake and i ran 11.53 at 118 in the summer heat so far. Car isnt launching all the way yet and its undergeared. should easily go 11.3's in the cool air at over 120
Your modded intake looks amazing! got to cut down on the huge heatsoak problem with these manifolds. i made 392whp on my 10th pull with coolant over 205 degrees. more in it for sure
Old Aug 9, 2008 | 10:45 PM
1SlowFormula's Avatar
this is looking good, can't wait to see one for myself one day...
Puck's Avatar
I was skeptical at first, but now with the pics I am sold.
Will be following your progress and plan on topping my stroker with one of those. Hopefully in red
Keep up the good work!
Old Aug 9, 2008 | 11:54 PM
Evaporate's Avatar
Thanks for the pics. You've mentioned that an FI version will be of significant benefit?
Old Aug 10, 2008 | 12:50 AM
hyperzone's Avatar
sweet. Is this going to be a wallet-buster intake or do you think you'll have a "standard version" that you'll sell alot of and leave it open for customizing at the added expense?
