is it possible???
Old Aug 9, 2008 | 05:29 PM
saylorZ28's Avatar
Default is it possible???
my car is full bolt on i am wanting to do cam swap ... stock heads and bottom in but want to work my way up to 10 or 11 1/4 mile times ... what is goin to have to happen do you guys think . all opinions welcome
Old Aug 9, 2008 | 05:36 PM
CamaroRacing12's Avatar
a nice heads cam package from AI and a small shot of nitrous will get u there
Old Aug 9, 2008 | 09:31 PM
saylorZ28's Avatar
what is ai ..
Old Aug 9, 2008 | 10:56 PM
Puck's Avatar
The more suspension goodies the better.
ET is really all about putting your power down. My PB was an 11.7 NA on the stock shortblock with some local shop ported "Stage Two" heads and a mild custom hyd roller cam similar to a stock cube spec'd LE2. That was with the stock salad shooters on all four corners, drag radials, and 90+ degree heat with only modest weight reduction. It surely had more in it but the tired old shortblock started to lose oil pressure so I retired it before it spun a bearing. That was at 160K+(!).
Was planning on 15" welds and skinnies up front and going for 11.5's stock shortblock with a bit more weight reduction, but never got around to it. If you plan on staying stock cubes do NOT overcam it with a huge off the shelf grind, since the motor will not last long if you spin to the rpms you will need to to run good times.
I appluad you for setting ET goals instead of HP goals like most do.
Old Aug 9, 2008 | 11:51 PM
LSWHO's Avatar
AI is advancedinduction.com
Also, do you have a 6 speed or auto? That makes a HUGE difference.
Old Aug 10, 2008 | 11:28 AM
saylorZ28's Avatar
thanks i want et's .... what good is 400 hp if you only run 12's and 13's lol spinning aint winning... .. my car is a4 it is a performabuilt tranny stage two .
