Myth or Fact. on 60ft.
Could it be the DA & alt. affecting it that much, are you guys doing this in the summer or in the fall @ sea level? I'm at 1500ft. & DA that night was around 23-2500ft.
I wonder if the reason some Standards bog on a dead hook is cause its suck a shock to the engine to have that much demand for power and it can't respond to it that quick cause the complete drivetrain is locked up when it gets the load applied..that is if you have a good clutch. The reason I say that is because with the Auto the Stall is going to slip internally then it's going to hit. You don't have that with the Standard.
There is a guy here in a pro-charged 402 LS2 Vette that dumps at like 5k and bogs every time. I have yet to see him launch without a bog. I wonder if it's a tuning issue as well..
The Merv. Yes i think it has ALOT to do with lack of power when trying to dunp the clutch like that, i'm at 270-280ish rwhp at best, the engine just can't respond fast enough to propel the weight its trying to move, 380-400rwhp would be a whole nother story, i'm sure the Alt. is effecting it too, thats why i don't believe its ever going to 60ft. in the say mid. 1.8s, even in good air, it does have a Ram clutch, once i leave & stab it, its like baaaaaaa & then its off, but its gradual, by that time, the 60ft. is over, god i wish i had an A4 now, hell i'de be in the 12s. These Hoosiers i'm running are every bit as good as a MT, i've run both & i can vauch for that, these Hoosiers freakin hook & hook hard.
http://www.youtube.com/watch?v=VYZ0hW6aDas
