Reluctor Ring = Crankshaft Sensor?
Thanks in advance.
Now, keep in mind, there are 2 pieces to this, the reluctor ring and the sensor. So if you go and buy the sensor, you won't get the ring with it.
Are you building a GEN II from a GEN I block? I don't quite remember, but I think there are some complications with doing that, but they can be overcome.
EDIT: You can see it in this picture, but obviously since we're looking for a P# it doesn't give it -_- It only has 4 'teeth' instead of 32ish like some.
http://shbox.com/1/engine_front_diagram.jpg
I had a lot of the other parts already, such as a turbo cam, heads, optispark, intake & tb, etc. Now I am going through and trying to figure out what I am missing and acquiring those pieces.
It appears that I am looking for the CPS reluctor, as it is named in the diagram. Neither the dealer nor gmpartsdirect listed the reluctor. Any clues as to where I might find this critter?
Is it press fit like some threads suggest, or is it just a slip fit like the diagrams suggest? I have nothing to compare it to, except the diagrams.
