Is the 383 Scat Pro Comp Series 9000 Crankshaft any good?
Is the 383 Scat Pro Comp Series 9000 Crankshaft desent or is it worse than stock.
what i wanna make is a 383 stroker with dart pro1 heads and a matched intake with a custom cam
3.750 Stroke Crankshaft - 383 -
5.700" Is the Minimum Connecting rod length required -
External balanced - Must be balanced prior to assembly
2.450" Main Journals - STD
2.100" Rod Journal - STD
1 Piece Real Main Seal
specs on crank
specs on crank
