My T56 Conversion..
The U-bolt for the Master Cylinder came in today, next week I'm buying the Hydraulics. I'll have more pics when I put them in.
So what exactly did the Bud Light help you accomplish today (if you even did anything since I last asked) other than getting drunk?
There is a such thing as "car work drunk" where you have that extra initiative, but then theres that line you cross where everything becomes harder because you just get lazy. At that point drinking more beer is really the only option.
When I get back I'm putting in the Hydraulics and the Petals, the U-bolt for it came in right before I left.
Your going to be looking at around 1k for a working, but decently used T-56.
The last thing I have left is to put the Interior back together. The Car will sit like this until I come back from Iraq, that is when I'll put in the T56, Clutch/Flywheel Kit, and the rest of the stuff that I have for it.
I dont know if the LT1's are setup the same way(I doubt it since it's the "LS1 Drill Mod"), but there is a factory restriction in the Fitting. You drill it out with a 1/8" bit to make the end of it the same as the Line.
The restriction was designed to not let you be able to get 3rd gear if you are quick enough with your shifting. It won't let the fluid in the line build back up to where you have enough petal for the 2-3 shift.
A friend of mine had an '01 Z28, he always missed third until he did this mod. I missed third with it was well.. the Petal would only come half-way back up.
