New Track Times!!
Old Aug 17, 2008 | 01:22 AM
94CamaroZ28SS's Avatar
Unhappy New Track Times!!
So i went to the track today Sacramento Raceway!!! i ran a total of 4 runs and wasnt very happy with my times, i installed an aluminum driveshaft today also thats not listed in my sig.
1st
Reaction .408
I1: 2.258
I2: 000
I3: 9.484
MPH (I3): 76.052
I4: 12.230
ET: 14.562
MPH: 96.380
2nd
Reaction .256
I1: 2.324
I2: 000
I3: 9.283
MPH (I3): 78.560
I4: 11.943
ET: 14.202
MPH: 99.4
3rd
Reaction .186
I1: 2.369
I2: 000
I3: 9.293
MPH (I3): 78.997
I4: 11.948
ET: 14.213
MPH: 98.354
4th
Reaction .207
I1: 2.103
I2: 000
I3: 8.992
MPH (I3): 78.933
I4: 11.645
ET: 13.911
MPH: 99.125
My best was a 13.6 a few months ago on a slipping tranny and the OPTI was on its last leg. I am disapointed!!! also the car felt like it would miss here and there at high rpms. Any suggestions to get my times down? i am going to get some 3.73 soon but what else would help?
Old Aug 17, 2008 | 01:25 AM
1_bad_TA's Avatar
Post up a slip. Just posting the et isn't gonna help too much.
Old Aug 17, 2008 | 01:43 AM
LSWHO's Avatar
Ditch the hypertech and get some sticky tires.
You should ET in the 13.7 range as is with a 2.0 launch, though. Not bad for a horribly geared and exhaust only auto.
Old Aug 17, 2008 | 01:56 AM
1_bad_TA's Avatar
You need drag radials bad. Just keep practicing. If your not red lighting, your not trying hard enough. Also think about weather conditions.
Old Aug 17, 2008 | 02:56 AM
Toronto_LT1's Avatar
if you weren't so far away,i would let you borrow my 315 NT555R's.
just keep practicing and get some sticky tires.
Old Aug 17, 2008 | 03:21 AM
LT1's Avatar
LT1
im guessing your rear rim is 18-19 inch
i would go down to 16 inch rim at the rear. Would gain more torque, help your time a lot.
Old Aug 17, 2008 | 09:48 AM
CamaroRacing12's Avatar
drag radials.
Old Aug 17, 2008 | 10:13 AM
I took the C6's Off and i ran my stock 17" Camaro SS wheels in the back.
Old Aug 17, 2008 | 11:46 AM
HoLLo's Avatar
Fix that "high rpm miss" you're talking about
Old Aug 17, 2008 | 12:44 PM
When i was at the track i had my friend put in drive and hold the brake to see if i could see any of the plug wires arcing off i also had him rev it up and i didnt see anything. I replaced my plugs, wires, and OPTI. Do you think it could be the COIL? i am looking at buying the MSD 8226. I think it might be that. My last pass it wasnt as bad.
Old Aug 17, 2008 | 12:53 PM
Fixxer99TA's Avatar
You were at least taking a good chunk off of your ET every time, so you were progressively getting better. If its missing up top it could be your opti (what kinda opti did you use for a replacement?). It could also be a number of other things (cut wire, one bad wire, coil, ect...).
If you dident see any arcing on the wires themselves, I think it would be time to check the opti. (And get some DRs, of course).
Old Aug 17, 2008 | 01:06 PM
yeah i was thinkin also it might be the OPTI. I got a ACDelco replacement OPTI and replaced the Old one about 15K miles ago! but like a Dumb *** i didnt replace the water pump which just went out like 1k miles ago and it was leaking out of the weep hole all over the OPTI. I bet thats whats wrong!!
Old Aug 17, 2008 | 01:14 PM
Fixxer99TA's Avatar
There ya go man, optis and hot coolant dont mix.
You will get codes before long if its bad, hopefully it dident get that wet.
Old Aug 18, 2008 | 12:31 AM
I think its fine now i think it dried out its not missing at WOT any more. I found out why it wasnt shifting from 2-3 i was low on tranny fluid. it pulls a lot harder now and has no problems shifting into any gear. My Bad for not checking!!
Old Aug 18, 2008 | 01:35 AM
Fixxer99TA's Avatar
You cant win em' all
Sounds like you got a bit lucky and the opti dident get soaked, they do dry out just not usually. Its just a question of the electronics and all and how bad it got wet, but you will know for sure before long.
Old Aug 18, 2008 | 07:55 AM
HoLLo's Avatar
I had a high RPM miss awhile ago. When I was racing, sometimes it would happen once or twice every gear towards 5k. It was almost like the fuel just cut off for a .0025 seconds or ignition. I found my MAF 12v wire was nearly cut all the way through, was barely held on. I replaced the harness and have not had an issue since.
Old Aug 18, 2008 | 04:16 PM
well i tested her out on the freeway i did a couple of hard pulls and it isnt missing anymore so hopefully its GTG now. I also was low on Tranny Fluid so i filled her up. she seems to be running fine now. She pulls a lot harder now that i filled the tranny fluid up to the correct level. I am going back to the track hopfully this week. I have new LCA's, panhard bard, and 3 point subframe connecters on the way i should have them in before i hit the track this week. WELL SEE WHAT HAPPENS!
