headers??
Old Aug 19, 2008 | 02:45 AM
iluvmuffz28's Avatar
actually its got some hi perf tranny or somthin, i dont kno exactly i forget what its calld. but tahts it
Old Aug 19, 2008 | 02:48 AM
goldmecham's Avatar
if you dont plan on doing a cam or f/i the shortys/mids will be fine but if you do go cam upgrade you will be spinning the motor to more rpms which will need a longtube header to keep up with the more air being moved.
Old Aug 19, 2008 | 02:53 AM
yeah i think im just gunna save up for long tubes, thanks alot for the help guys
slagger's Avatar
mine has the y pipe it pretty much goes right where the stock cat goes
Old Aug 19, 2008 | 02:56 AM
goldmecham's Avatar
just remember when your doing mods make sure you have a plan and get parts that will work for that plan so you dont have to buy parts over again.
Old Aug 19, 2008 | 02:59 AM
if i get long tubes, will i need anything else or will it all work out with everything i have?
Old Aug 19, 2008 | 03:03 AM
goldmecham's Avatar
if you get long tubes get the best you can afford if you have to save longer to get stainless or coated ones it will be well spent money in the long run, and if your staying with a stock style exhaust you will need to get a matching y-pipe. if you do end up doing true duals you will need pipes fabbed up but wont need the ypipe. and get better header gaskets then what comes in the kit. i use copper ones from mr gasket and ive used felpro header gaskets with good results.
Old Aug 19, 2008 | 03:07 AM
no i already have the true duals. i just need headers to hook up to them...
Old Aug 19, 2008 | 03:08 AM
goldmecham's Avatar
so just save up for some coated pacesetters and get better header gaskets then.
Old Aug 19, 2008 | 03:10 AM
dude, im seriously thinking about just gettin rid of the borla duals and gettin a borla catback and just doin the y pipe thing, with long tubes. what do u think?
Old Aug 19, 2008 | 03:26 AM
goldmecham's Avatar
the fitment would be better with a y-pipe and a catback. i know you like borla but you might check out the hooker cat back. its one of the best sounding ones out there.
Old Aug 19, 2008 | 03:29 AM
  #32
ill check them out, thanks bud
Old Aug 19, 2008 | 11:14 AM
  #33
Fixxer99TA's Avatar
+1 on the hooker catback, its going back on my car when I get Longtubes/ORY for this car.
