Plastic Shield Inside the Door
Old Aug 19, 2008 | 02:00 AM
Counted Out's Avatar
Default Plastic Shield Inside the Door
I'm changing my drivers side window motor and when I took off the panel the plastic vapor shield like thing inside the door was pretty messed up. Do I need this thing? If so, is it possible to buy a new one?
Old Aug 19, 2008 | 02:17 AM
Fixxer99TA's Avatar
As far as I know the dealer still has these. If your car doesnt see rain/snow/moisture in general and is garaged, I wouldent worry about it. If it sees anything like that then you might have a problem with water destroying the metal parts in the door.
Old Aug 19, 2008 | 02:43 AM
It doesn't see those much being in Tucson, but occasionally we can have our moments of rain.
Old Aug 19, 2008 | 07:54 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I would fix it, to be correct. But considering your humidity is below 10% and you dont see much rain, you can get away with not fixing it.
Old Aug 19, 2008 | 11:04 AM
Fixxer99TA's Avatar
True, If it were me Id fix it just cus it wasnt...
But its not a huge deal, not going to leave you stranded in the breakdown lane of the local highway anytime soon
