Spark Plug Torque specs?
Old Aug 21, 2008 | 03:55 PM
187fl's Avatar
Default Spark Plug Torque specs?
Im going to be changing the spark plugs on my car tommorow but before I do that I wanted to ask you guys a question on the torque specs. I have a chilton book on these engines and it tells me that the torque specs on spark plugs is well over 100 foot pounds. But when I bought the plugs the box said it was something like 30 foot pounds. I dont have the exact numbers cause im at work but which one is it? BTW the plugs are ngk's
Old Aug 21, 2008 | 04:00 PM
Badazz 97 TA's Avatar
have fun getting a torque wrench down there. wtf! just snug them down. they dont need to be rediculously tight. there aluminum heads so dont go crazy tight on them.
no need for a torque wrench.
Old Aug 21, 2008 | 04:08 PM
187fl's Avatar
Its my second time changing them, I'ts cramp as hell down there lol, but I just wanted to put them on the right way. I will be going on feel if i cant get the torque wrench in there.
Old Aug 21, 2008 | 04:12 PM
MadMike 97 Z28's Avatar
WHOA!!! WHOA!!! easy with the 30ft. lbs. you just need to snug it up probably in the range of 10-15 lbs but.
it would be really bad if stripped it out so be careful.
Old Aug 21, 2008 | 04:21 PM
187fl's Avatar
I had a feeling they didnt go on so tight, thx guys for the info
Old Aug 21, 2008 | 04:27 PM
connexion2005's Avatar
15ft lbs is the spec...
Old Aug 21, 2008 | 10:56 PM
S2K's Avatar
S2K
From: Bristol, TN/Knoxville, TN/Mooresville, NC/Phoenix, AZ
Last I checked they are 11ft.lbs. And are you sure the chiltons didn't say it in in.lbs.? Because over 100in.lbs. would be right.
Old Aug 21, 2008 | 11:45 PM
Fixxer99TA's Avatar
Doesnt have to be exact, just get em' tight and dont strip them out. If you accomplish both then your golden
Old Aug 22, 2008 | 01:14 AM
187fl's Avatar
I just came home and I checked the Chilton book and it was 132 in/lbs. And the box on the plugs said 7-14 lb/ft for aluminum heads. You guys were dead on.
Old Aug 22, 2008 | 12:46 PM
S2K's Avatar
S2K
Don't forget the anti-seize. :O
Old Aug 22, 2008 | 01:13 PM
wrd1972's Avatar
15# - 20# Max
