Help me
Old Aug 21, 2008 | 06:53 PM
mattslightning's Avatar
Default Help me
Ok guys. I picked this 95 t/a up on sunday knowing the car did not run and what is wrong with it. So I started with the ignition. The car use to just crank over and never fire. I installed a new ignition module, coil, and new gm opti today. Now the car will fire and try to idle but is barely idling. BARELY would not even call it that. Then dies. Its seemed like everything went together really well and did not have to force anything to fit. Any ideas would be greatly appreciated! Oh and all fuses are good as well as all connections
Old Aug 21, 2008 | 06:59 PM
IronOutlaw's Avatar
What do the spark plugs look like? have you checked the fuel pressure? may want to change the fuel filter its something cheap you can try.
Old Aug 21, 2008 | 07:11 PM
I have good fuel pressure. The plugs look ok.
Old Aug 21, 2008 | 07:18 PM
IronOutlaw's Avatar
Have you checked your plug wires and made sure you didnt cross any of them?
Old Aug 21, 2008 | 07:24 PM
GLT1's Avatar
im guessing its the fuel filter,pump or ecm
Old Aug 21, 2008 | 07:27 PM
LT1's Avatar
LT1
One way i can tell if fuel filter is clogged, remove it and blow threw it (the correct flowing direction) if its hard to blow then its clogged, if it blows fairly easy then most likely ok.
Old Aug 21, 2008 | 07:33 PM
indirocz28's Avatar
1. Go ahead and change plugs and wires even if they look " ok" they are cheap enough
2. fuel filter anyways cheap enough
3. any check engine lights?
4. see if anyone has a scanner to monitor Idle air control valve operation
If none of these work- see if the exhaust is clogged by taking out the forward o2 sensors.
Old Aug 21, 2008 | 07:56 PM
IronOutlaw's Avatar
Gut the cats...
