Difference between 93 LT1's & 94-97 LT1's
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I need help with a question that I can never seem to find the answer too!
What are the differences between 93 LT1's and 94-97 LT1's. I have a 93 formula LT1 T56 and every time I look at any bolt ons etc. in magazines there is always a seperate part for 93's only then another for a 94 on up such a Throttle Bodies, The LT4 kit says 94-97 LT1's, and many other parts.
WHY IS THIS?
I do know that 92-93 LT1's are Speed Density and 94-97's are Mass Air Flow but that does help me.
Please clear this up for me!
WHY IS THIS?
http://www.speeddensity.org/showthread.php?t=679
93s don't use a MAF
93-94s use a non-vented opti-spark
93s are speed-density and use a removable chip, 94+ have non-removable flash chips.
93s has smaller injectors (22# VS 24#)
93s had different gearing in the M6s (two options available)
93s did not have CAGS ("Skipshift")
93s had a different IAC (screw in VS bolt in)
See the thread I linked for more
93s don't use a MAF
Thanks that clears up some stuff, nice to know that 93's didn't have the (cags). When I first got this car I figured all T56's had the skip shift so I bought the delete wiring for $30 right away and came to find out my car didn't have it, so as a NEWBIE to 4th gens I thought my car had some special skip shift delete option and now I know (DAMMIT!) haha I own six 3rd gens so I am very familiar with those, but this is my first 4th gen so im still figuring them out.
Thanks
My 3rd Gens consist of:
1985 Maroon WS6 Trans Am M5 350 TPI 3.42 Posi, 4-wheel discs, T-Tops, has all available options that year could have (1 of 731) Current full body resto in progress.
1985 Red firebird A4 hardtop 4bbl 305 Pw/Pl (nothing special)
1988 Maroon firebird A4 T-Top 3.4 V6 (Gas saver)
1987 Red Trans Am A4 T-Tops 305 TPI ( rare H.O. 305 called a STAGE 1 5.0L H.O.)Pw/Pl, Rear defog (needs some body work)
1987 Maroon Trans Am A4 4bbl 305 H.O. My First Car Completely restored from ground up (Completely totalled it 4 months after fresh paint after a full-size van T-Boned me, sad really)
1987 Blue Firebird Formula Hardtop M5 305 TBI ( sold it so I could buy my 93') No I'm not rich I just find great deals haha.
Thanks for your replies!
No traction control either and I'm 95% sure no t-tops. Throttle body is also different, mainly due to different transmissions and the IAC change. The autos weren't computer controlled, just a normal 700R4 in them. The 10-speaker versions weren't Monsoon and have a different amp. Intakes are different, 93s are better w/o the fuel rail crossover in the middle of the plenum (wth were they thinking?). So if you buy a ported one off eBay and it says "93-97" make sure that it's a 93, since they basically only work on 93s unless you change fuel rails. The stock manifolds and emissions stuff is slightly different, and the AIR motor was frame mounted instead of motor mounted.
That's all that comes to mind right now.
No T-tops...some claim they are lighter and a little faster...dunno if that is true or not. It has the chevy pink rods, the passenger side airbag does not say camaro or air bag on it. Everything else is true, it is a speed density car. They are just as good as any other car...also in the camaro no leather interior was offered. One other thing about the throttle body, the auto transmissions have the t.v. cable while 94 started the electronic trans...93's have a 4l60/700R4 while the 94 has the 4l60e. The cam needs the splines in the front to put the opti, the later lt1's have a dowel pin. Any other questions i am sure people can answer on the board...welcome!
93s had TTops available. Either that or someone cut a hole in my roof LOL
I know of several 93 Birds with TTops. IIRC, Camaros also had that option.
I don't believe there were convertables available that year though.
"Pink" rods were used in 93-early 95 LT1s, they were later replaced with PM rods (which are actually stronger)
And no, they are not really painted pink.
Here are a pic of my stock rods/pistons. They're listed over in the for sale section.
![](http://i38.photobucket.com/albums/e146/jmontign/93%20Firehawk/For%20Sale/img_3924jpg.jpg)
They're not pink, but from what I recall from a picture of original rods, they have a pink hue to them. So no, yours won't show that since they're used and covered in oil ![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
EDIT: Oh our fans aren't 2-speed either
Not sure about 94s, but we use the single-wire O2 sensor. No TCS.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
93s don't use a MAF
93s don't use a MAF
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
OK, correct there ARE T-Tops in 93. Just very few! It was Vert I must have been thinking.
1993 - Model Breakdown:No verts
Model----Total---Hard--TTop---A4-----M6--AR9--1LE--R6V--UP3
Firebird--(5006)--4622--384--.4434---572--N/A--N/A--N/A--302
Formula--(3985)--2929--300--3229---756--790-.--3---201--520
TransAm-(5121)--4282--839--4018---1103--?-----0---N/A--2369
Special Options: AR9 = Leather / 1LE = Perf. Suspension / R6V = Firehawk / UP3 = Compact Disc
