Need advice:Installing my GMMG
IDK if it bolts up to the stock cat or not. Never really had to deal with any of that since I went with a ORY.
Hope everything goes smoothly for you though!
- Mike
Depending on you header/manifold setup, you just cut your old pipe under the car, after the cat and the GMMG is designed to just slip over your old pipe and tighten with the supplied clamps. Its a very easy install.
I had to cut my old exhaust two times, before the rearend and after the cat.
Put the mufflers/resonators in first then put the straight pipe on and measure where you need to cut the old pipe out.
I had flowmaster before the GMMG. You will love it!
And thanks Corey, we never did get to hang out but oh well working 10 hour days - six days a week is good money
Now I just need gears and a stall...
