had a weird problem?!
What could this be? Its a stock internal, just bolt on car with a shift kit. It was almost acting like it had a big cam in it. I'm confused
- Mike
I'm clueless.. I changed the plugs about a week ago. Maybe they are already fouled out? I'm going to pull one tommrow too see. Anyone ever have something like this happen to them before?
- Mike
Just thought I would throw that in there too.
TPS sensor is my guess, resulting in far too low voltage and giving it gas raises it to normal levels. Or possibly the IAC is stuck either all the way open, or closed.
Oil pressure I assume is related to the fact the motor was changing RPMs from really low to fairly high? If not, might just be like my problem, gauge or sensor going out. Mine will flicker around sometimes too, but I know my OP is good.
