need timing chain with cam swap?
Old Aug 29, 2008 | 01:25 PM
lt1z28camaro's Avatar
Default need timing chain with cam swap?
Is it recommened to have a new timing chain put in when doing a swap? I only have 40k on car..
Old Aug 29, 2008 | 01:26 PM
Elliott's94Z's Avatar
w/o a doubt...I have a spare chain I just picked up for 30 bucks..cheap swap and you will have the comfort of knowing you did it.
Old Aug 29, 2008 | 01:28 PM
40k...damn that pretty sweet. Take a look at the opti as well to see what kind of condition thats in too. Better to do all this while you are in there. I vote for an electric water pump too!!
Old Aug 29, 2008 | 01:29 PM
Where should I look to get one? I don't know much about them..Is there a "better" one than others? Sorry if these are dumb questions..
Old Aug 29, 2008 | 01:33 PM
Well you can upgrade to a double roller chain if you want. Thing is if you do you will have to change over to the opti spark 2 conversion and change the timing cover along with some other stuff. Cost wise it's really not worth it if you are running just a cam. You will be fine with the stock one. Check a local chevy dealership for the timing chain.
Old Aug 29, 2008 | 01:39 PM
Here is your GM part number for the stock timing chain...10128485. Call these guys and ask for parts and they can order one up for you...503-232-2000
Old Aug 29, 2008 | 01:42 PM
it's cam and heads, do you think stock opti will be alright?
Old Aug 29, 2008 | 01:44 PM
Kinda goes along with changing the timing chain...although you may not be having any problems right now, you might down the road soon. I say change it because you will be right there and again...have the comfort of knowing you did it and it's new
Old Aug 29, 2008 | 01:46 PM
What head and cam package you doing?? Throw your mod list up in your sig!
Old Aug 29, 2008 | 01:52 PM
haha i'm going to once i get all of this put in, i'm getting le2 heads with one of his billet cams 228/235, lpp headers, (have mid's right now) and all the little things/rr's, pushrods,lifters,valves,springs.. Would i be alright getting just rotor and cap? or just do a full opti replace? (after all the parts my funding is running low haha)
Old Aug 29, 2008 | 02:00 PM
Do the full opti. That package is awesome. I have spoke to Lloyd a few times..nice guy! You are gonna have to do a stall and prob some gears too.
Old Aug 29, 2008 | 04:16 PM
I have m6, gonna run the 10 bolt til it craps out. then 4.10's. yeah he's a good guy, knows his stuff definately. and thanks for the help on the opti/chain man.
Old Aug 29, 2008 | 04:19 PM
No worries man. $100 bucks say's you blow that 10 bolt with the M6..LOL I see a 12 bolt in the future Good luck with that set up!
Old Aug 29, 2008 | 06:36 PM
Badazz 97 TA's Avatar
what year is your car? if you have the vented opti i would go with the gm LT4 heavy duty chain. otherwise a stock replacement will work also. i would change it if i was in there. i had 59,000 miles when i did my cam and the timing chain was all stretched out.
Old Aug 29, 2008 | 08:55 PM
James Montigny's Avatar
Exactly. Cheap insurance.
I had a chain with 8K miles on it and thought it would be good. When we checked it, it had way too much slack in it.
And that was a brand-new Lunati (rebranded GM) timing set I had installed only a year previous.
And don't forget to degree that cam when you install it.
It's a hell of a lot easier to check it now, then to pull your hair out later
trying to figure out why you cam doesn't act the way it should.
Offset bushings are cheap and any machine shop can drill the offset without to much trouble.
(Don't expect to penetrate powdered metal timing sets with your cordless drill)
