high rpm miss
Old Sep 8, 2008 | 07:18 PM
StangeatinZ28's Avatar
Originally Posted by jarretthise
sounds like a valve problem to me....and on a stock bottom end you shouldnt be running it much past 5500 anyways...it will take out your bottom end...was this running for the dyno or something
i run mine past 6 grand and no probblems
Old Sep 8, 2008 | 07:20 PM
96capricemgr's Avatar
No Granatelli, go Racetronix. For a long time there was only one company making the 255lph pumps and it was Walbro but more recently it seems a chinese company has started making some cheap.
I say go Racetronix because the kit will fit better than any other, is a Walbro pump very much like all the others but the details make it worth it. Go with the wiring upgrade too, for the price you can not build anything half as nice.
I tried using a higher volume GM pump and a DIY wiring upgrade and ended up buying the Racetronix kit later anyway.
Old Sep 8, 2008 | 07:57 PM
ElkySS's Avatar
would you mind giving me a link to it. i am on a tight budget at the moment tho
Old Sep 8, 2008 | 08:34 PM
http://www.racetronix.com/RX-FLT1-FPKG-2.html
The wiring upgrade makes sure the pump gets adeuate voltage. Cars are run with pretty much the bare minimum wiring sizes and a higher capacity pump will draw a little more power.
