LT1 in a 69 Camaro wiring Question
Old Sep 3, 2008 | 04:15 PM
cencal69's Avatar
Default LT1 in a 69 Camaro wiring Question
O.K. Que the dead horse but I can't find which wires need to go and which ones need to stay on a stock 96 wiring harness. I have the diagrams but I'd like to know if anyone has a list of what they've used that has worked, and what wires they've removed.
The engine & T56 tranny are going into a 69 Camaro.
Thanks in advance,
Gabriel
Old Sep 4, 2008 | 10:53 AM
cencal69's Avatar
I might have worded the question a little bit funny. What I'm looking for is what is necessary (which wires from the PCM) to make the LT1 run, and what wires should be removed. Thanks again.
Old Sep 4, 2008 | 01:04 PM
Z48LT-1's Avatar
shbox.com has wiring diagrams that will help. There are numerous other sites with information that would help, as well. Painless, among others, sells a harness that you could use. Your problem is a lot more complicated than could ever be resolved in a forum. You need to do a lot more searching.
Best -- Gary
The HybridZ web site (hybridz.com) has a numerous posts about adapting LT1s to other platforms, but again, you'll need to do some research. Good luck.
Old Sep 5, 2008 | 08:40 AM
hoosierdaddy's Avatar
Smile speartech
I sent my harness to Speartech and they did a great job. Just tell them what you want left in the harness and they will return it with everything marked and ready to install.
www.speartech.com
Old Sep 5, 2008 | 08:55 AM
the_merv's Avatar
Veteran: Air Force
If you are familiar with Pinout Diagrams and what the names for the Wires are, you can get it yourself.
Old Sep 5, 2008 | 01:55 PM
malibu2slow's Avatar
with shbox u cant go wrong , why is it most people who ask for whiring help only make 1 post and never come back ?
