Emissions Help!
Old Sep 9, 2008 | 10:51 PM
bowtiekid's Avatar
Idk how!! lol.
Ive tried the method on shbox's site like 2 or 3 times.
So i guess the SES light will epxlain it all to me I just need a way to find out what it is
Old Sep 9, 2008 | 10:55 PM
Formula350's Avatar
Originally Posted by bowtiekid
Idk how!! lol.
It makes the SES flash if you jump the right 2 pins. Example: Flash-Flash pause Flash-Flash-Flash-Flash would be code 24 (example, no idea if there is a code 24).
Fixxer99TA's Avatar
Yes, the SES more than likely holds the key
Old Sep 9, 2008 | 10:58 PM
bowtiekid's Avatar
I understand that.
But what im saying is will any OBD1 scanner from checker or autozone work?
Or is it something fancy? lol
And yes hopefully it does. I want it to pass so I can ditch this lame exhaust with cats ha ha
Old Sep 9, 2008 | 11:39 PM
Formula350's Avatar
I understand that.
Yours might have the OBD2 connector, and yet be an OBD1 car, and I think that's a problem for some scanners. Advanced, Checker and I think AutoZone as well (I know the first 2 do, I worked at Checker) can scan them.
Old Sep 10, 2008 | 05:37 PM
bowtiekid's Avatar
Already tried those places and no one can scan it
Old Sep 10, 2008 | 05:57 PM
Formula350's Avatar
See, I'm wondering if it's incompetence on their part.
Do you have an ODB2 connector?
Yes? -Are they testing it as OBD2?
No? -Are there scanners capable of OBD1?
If yes: Tell them to test it as OBD1
If they can't: Take it to a shop, usually they'll test free to get you in the door.
If no: See "If they can't"
My scanner that I have, was the same one we used at Checker 4 years ago, and I can swap plug ins and specify if I'm testing OBD1 or 2, even if I have an OBD2 connector on it. I also have real-time readings of sensors and other stuff the E/PCM is seeing
Old Sep 10, 2008 | 05:59 PM
AChotrod's Avatar
Can ya stop by a dealership? They do it for free if you just walk in and ask most the time.
Old Sep 10, 2008 | 06:09 PM
bowtiekid's Avatar
Im gonna try shbox's method with a OBD1 scanner and jumping the wires and see where that gets me. If not that I guess I will have to go somewhere to have it scanned.
Old Sep 10, 2008 | 06:52 PM
Formula350's Avatar
Well I didn't know that 94 and 95 didn't flash haha Learn something every day
I assume this is the method you're attempting (in the Note portion)
http://shbox.com/1/dlc2.jpg
Old Sep 10, 2008 | 08:15 PM
bowtiekid's Avatar
Im just gonna take it to a shop and have them read it so I can fix it
Old Sep 11, 2008 | 02:13 PM
  #32
bowtiekid's Avatar
I got the PCM scanned to day and I have the following codes being thrown..
23: IAT sesnor, Low temperature indicated
26: EVAP Purge Control Circuit Fault
37: TCC brake switch errorm TCC Brake switch stuck on
51: Faulty or incorrect PROM/EPROM
37 could be caused by the B&M Shift+ thing module I have.
26 states its a wiring error
23 I dont even know how I could have low temp indicated when I dont even have a CAI lol
51 could that be my tune??
