HELP HELP HELP anybody, i hate this lt1 :bang:
Old Sep 7, 2008 | 09:52 AM
robsquikz28's Avatar
results with plugs out and compression tested!!!!!
also since we all think maybe a blown head gasket how bout using a block check that will tell u if you have a blown head gasket!
but the trashed cam idea sounds a bit more legit but we need to pinpoint this in every mechanical way before the engine tear down.
Old Sep 7, 2008 | 07:12 PM
jarretthise's Avatar
run these tests like i said it might have something to do with my examples....let us know what you find out man...make sure there are NOOOO plugs in the block and then do your compression test
Old Sep 7, 2008 | 07:33 PM
Formula350's Avatar
Originally Posted by Fixxer99TA
Thats right, heat not electricity.
See, I do know some stuff
I still find it comical they include that, given the placement of it on our cars
Might as well fireproof a log you plan to put in the fireplace
Old Sep 7, 2008 | 07:47 PM
daville_pits's Avatar
any results yet on the compression test
Old Sep 7, 2008 | 07:53 PM
Fixxer99TA's Avatar
I have been wondering myself....
Old Sep 8, 2008 | 12:16 PM
Hemby207's Avatar
Hey guys sorry about the wait, work has been getting in the way. The other day i had time to remove the valve cover and check the springs for number 1. The rocker was adjusted fine but the spring itself on the intake side was not moving near as much or as "snappy" as the others. It was however close but you can see a slight difference in travel and time in comparison to the others. Im leaning on a weak spring (have to order a tester) or a flat lobe on the cam.
Old Sep 8, 2008 | 12:31 PM
Formula350's Avatar
While it's possible, I haven't heard of many of our cams going out as far as lobes go. I'd lean more towards springs, and if you by chance have 1.6 ratio rockers, then even more so. Our stock springs are only good up to stock lift @ 1.5 heh
Old Sep 8, 2008 | 12:39 PM
Fixxer99TA's Avatar
Yeah, havent seen any of these cars eat cam lobes in awhile (but I have before, it does happen). Its more than likely adjusted improperly OR you have a weak spring..
I would still VERY MUCH like to see compression numbers though
Old Sep 9, 2008 | 10:56 PM
Hemby207's Avatar
Alright the compression numbers with all the plugs out are as follows:
1- 166
2- 167
3-168
4- 169
5- 167
6- 167
7- 168
8- 169
All seem fairly consistent but that 166 is kinda low but should still be enough to fire.
Old Sep 9, 2008 | 10:57 PM
Hemby207's Avatar
Also i did check the push rod for number one and it was fine also readjusted the rocker which did appear to run correctly and looked fine
Old Sep 9, 2008 | 11:13 PM
Fixxer99TA's Avatar
Someone correct me if I am wrong, but proper compression on an LT1 is 170-190?
