Need Help with the Water Temp. Sensor.
Old Sep 8, 2008 | 09:37 PM
SStriker's Avatar
Default Need Help with the Water Temp. Sensor.
Anybody have a pic of where its located, (the water light on the dash is on)
I do bealive this is the problem. Am I right or is it something else...
Is this a Dealer part?
Is it hard to change?
Thanks for any help...
Old Sep 8, 2008 | 09:39 PM
Doc Mitch's Avatar
the water temp sensor is on the waterpump. the low coolant light on the dash is connected to the low coolant sensor. it is a common problem for this sensor to get dirty or mess up. just check the coolant level. this is where the sensor in question is at
Old Sep 8, 2008 | 09:42 PM
Fire67's Avatar
If your coolant level is good, then either replace or unplug the level sensor to extinguish the light.
Sensor is located on engine side of radiator, directly below the cap. Rectangular body with a wire clip holding it in place.
Old Sep 8, 2008 | 09:55 PM
SStriker's Avatar
Bada$$ Guys....thanks For The Help...
