Battery Relocation..Progress Thread
Old Sep 13, 2008 | 08:40 AM
  #41
lethal93ta's Avatar
I bought an Afco battery mount from summit or jegs I forget witch and welded tabs on there for mounting, its the same things BMR one they sale for 100+ for a 1/4 of the cost, I got my wire local the most expensive part was my kill switch flaming river isnt cheap but they make really nice stuff.
Old Sep 13, 2008 | 10:42 AM
  #42
BIG_T's Avatar
http://www.flamingriver.com/index.cf...prod/prd62.htm
this the switch ur running lethal93ta?
Old Sep 14, 2008 | 01:40 PM
  #43
the_merv's Avatar
Veteran: Air Force
Today I put in a Coolant-Overflow Resivoir inplace of where the Battery was. I got it from a friend of mine, he had it laying around his shop.
Old Sep 14, 2008 | 01:45 PM
  #44
lethal93ta's Avatar
yep thats the one i have.
Old Sep 15, 2008 | 07:01 AM
  #45
BIG_T's Avatar
i was planning on ordering it and after seeing it installed it put the nail in the coffin so to speak thanks man
Old Sep 15, 2008 | 11:48 PM
  #46
the_merv's Avatar
Veteran: Air Force
I ran 2ga from the back to the starter and 4 gauge from the alt back so the kill is NHRA legal. I have a flaming river push/pull kill switch hooked up. I welded a 1/2" bolt right to the body for my ground.
Couldn't you have put the Switch on the Ground Wire off of the Battery instead of going through all that Wiring for the Positive side of the circuit..
Old Sep 16, 2008 | 04:16 AM
  #47
lethal93ta's Avatar
NHRA rules the cut off must be on the positive side.
Old Sep 16, 2008 | 08:15 AM
  #48
the_merv's Avatar
Veteran: Air Force
Ah.
Well today I finished it, I completed the Box I made for it, and bolted it all in.
Old Sep 16, 2008 | 09:33 AM
  #49
Ihasfip's Avatar
I wish I knew how to post pictures on here... I would show you my setup. I put a hidden nitrous setup on my car and put a fake battery under the hood and put my optima in the back in a battery box. Its pretty clean. No cut off though...one of these days I will. I don't race it enough at the track to justify putting one on it. Not until after the cam and stuff.
Old Sep 20, 2008 | 02:40 PM
  #50
pddye's Avatar
Ihasfip - I use webshots to post photos. Just load them in webshots and then when you are looking at that picture on the lower right hand side there are links you can copy and paste here on the forum. I usually click the 500 size and them copy the in a forum link here.
Old Mar 3, 2009 | 09:12 AM
  #51
xx_ED_xx's Avatar
Silly question. Has any of you with the cut off switch. tried to shut your car off when running? I know on my 71 the alt would keep the car running. Or does the switch shut off the feed from alt as well?
Old Mar 3, 2009 | 10:04 AM
  #52
Formula383's Avatar
Good info in this thread. Glad you got it finihsed up Merv. This is how I did my relocation.
Postive Cables
0 ga. from battery to switch
1 ga. from switch to starter
4 ga. from switch to alternator
4 ga. from starter to distribution block
Negative Cables
1 ga. from battery to frame
4 ga. from block to distribution block
4 ga. from block to frame
Factory ground strap on driver side
And here's a few pics. I still need to trim the the hold-down bolts a little.
Old Mar 3, 2009 | 10:09 AM
  #53
xx_ED_xx's Avatar
Kyle NHRA dont bitch about not having a metal wall between you and the battery? And you mounted it on the driver side?
Old Mar 3, 2009 | 10:16 AM
  #54
the_merv's Avatar
Veteran: Air Force
I beleive the NHRA rules state that you have to have the Switch on the Alt. Cable to cut the Power to it.
Old Mar 3, 2009 | 10:19 AM
  #55
xx_ED_xx's Avatar
IS this a new style switch. unfortunately it has been a few years since I last had this setup. 9 to be exact
Old Mar 3, 2009 | 10:24 AM
  #56
Formula383's Avatar
Yeah, it's mounted on the driver side. All my nitrous stuff is on the passenger side and I didn't want the battery out in the middle of the well.
It's my understanding that a firewall or box isn't needed because the optimas are sealed batteries.
Old Mar 3, 2009 | 11:16 AM
  #57
xx_ED_xx's Avatar
Ah ok. Thanks
Old Mar 3, 2009 | 03:20 PM
  #58
lethal93ta's Avatar
you need to run a wire from the alt to to the back of the car and put the wire on the battery side of the cut off switch then when you hit the kill it will shut the car off. see my pictures.
Old Mar 4, 2009 | 10:57 PM
  #59
scj's Avatar
scj
i'm really interested in doing this, but i'm kind of clueless when it comes to finding some wire?
where would i go about buying some 0 gauge wire like this?
what should i expect this to cost per foot?
how many feet should i need to go from the stock battery location to the rear spare tire well?
then last but not least, where and how can i go about putting ends onto the wire, like so i could put bolts through them?
sorry for all the questions, help?
Old Mar 5, 2009 | 07:42 AM
  #60
Black94Z28's Avatar
Very good information...now that the weathers slowly warming up, im gonna attempt to finish this on my car.
