building a TT Lt5 in a 1983 corvette. what oil for breakin?
#101
http://www.pnwzr1.net/Jeff/accel.AVI
#102
From a dig the technology in the C6 Z06 is brutal. I think you be surprised in a roll from 100 plus. The stock ZR-1 would not stay even, and it shouldn't as it is down 100 hp at the wheel, and the torque is a wide separation as well, but the ZR-1 would not be embarrassed.
take a look at the C5 Z06, those were rated at 450hp IIRC, so that would only put the ZR-1 from 91 like what 30-50hp down? i cant remember their exact hp rating stock.
#104
i dont think the one we have was the prototype.
somewhere in the neighborhood of 23psi
#105
1. Elongated nipple for fuel pressure regulator vacuum
2. Non flat finish in casting for throttle linkage brackets
3. Cam cover with solid fitting for fresh air intake to cam cover
![](http://www.pnwzr1.com/images/motorLS1tech.jpg)
#106
So how is the aftermarket parts market for the LT5? I allways thought it would be awesome to get my hands on one of these engines and bore/ stroke it, work the heads a little, some good valve springs, and some mean cams. Mainly worried about the crank and cams, what are out there for them, and how ungodly is the price? What is the bore spacing on these things? Close to a SBC at all? It would be awesome to retrofit them on a LTX engine. 32valve LTX dumdumdum!!!
#107
#108
Crank is 5k.
Cams new custom grind 3,200
Standard chevy bore spacing
Valve springs aren't needed as you max out at 470 lift.
Typical engine stroking
368 (bore only)
385 4" bore x 3.875 stroke
402 4" bore x 4" stroke
415 4" bore x 4.125 stroke
Couple of 421's and 427's out there and a 440 cube car. 440 engine will cost you around 45k.
#109
Wow that's a little worse than I even thought haha. Who makes the cams and the crank? What do you mean by "Valve springs aren't needed as you max out at 470 lift"
Have you ever seen just a bare set of heads sell for them? I would love to have a set, especialy since they use SBC bore spacing.
#111
Couple of crank manufacturers, Sonny Bryant & Jerry Crews
The max lift you will see is 470 ish. The stock springs are fine.
#114
It looked like you were shifting around 7300 rpm?
Late to the LT-5 game (last year) and trying to learn what I need to know over on the KOTH boards. Goal is to make 500 fwhp w/stock cid.
#115
I think he meant the max lift, as .470, due to having twin cams. not needing as much lift due to having an extra valve to do 1/2 the job of the standard, so they're smaller and less lift. I'm sure you figured that out though
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
There's an engine builder here in MN that's quite respectable I guess. Has quite a few LT5 packages available and range from 415hp to 600hp @ 402cid (I swore he had 427 and I though I saw a 454ci, but apparently not)
The guy is Dough Rippie and it's his name, no space and .com (not a sponsor so no linky linky!)
Pics from the engine page
![](http://www.dougrippie.com/images/_33.jpg)
![](http://www.dougrippie.com/images/drm-1.jpg)
#116
Here's a breakdown from Marc Haibeck, one of the top LT-5 builders/tuners on how to get 500 hp at the crank from a stock cid LT5.
Component Packages for a 350 Cubic Inch Engine
Upgrade '90-'92 HP '93-'95 HP
Stock engine power 375 405
Low back pressure exhaust system and performance
engine calibration (chip). +20 +10
Sub Total 400 420
Long Tube Headers +25 +25
Sub Total 420 440
Top End Porting +30 +25
Sub Total 450 465
Cylinder Head Porting +35 +20
Sub Total 485 485
Aluminum Flywheel +15 +15
Total HP 500 500
http://www.zr1specialist.com/HAT%20W...20upgrades.htm
That link also shows the power output of some of his various stroker builds.
He's got a ton of tech info at the home page.
Sub Total 400 420
Sub Total 420 440
Sub Total 450 465
Sub Total 485 485
Total HP 500 500
