PCM Help
23: IAT temp too low
26 : EVAP Solenoid Control circuit fault
37: Brake switch stuck on (ABS light)
51:
EPROM/PROM ErrorIAT is easy, it got wet so thats prolly why its messed up, the EVAP I dont kow about that one, and the brake switch on? Probably my brake pedal is hitting the brake light switch, and the EPROM error... I hope I dont have to buy a new PCM
[edit] If it matters. but if I idle for a long time my volts will slowly start to fall.
