Car won't turn over
I'm not sure if your car has one, but some cars also has a sensor that shuts the the fuel pump off to avoid damaging / sucking air into the line if you run dry. You might have a code locking your fuel line off. If you have a scanner check for codes, otherwise I hear tell disconnecting the battery for 30 seconds will sometimes clear the code off.
