newbie is curious
Old Sep 16, 2008 | 05:34 PM
wicked383lt1's Avatar
Question newbie is curious
what would be considered full bolt ons on a lt1?
Old Sep 16, 2008 | 05:35 PM
BlackTTC6's Avatar
Headers, Catbacks, Y Pipes, Nothing internal
Old Sep 16, 2008 | 05:55 PM
cool thanks thats what I figured but I didn't want to assume anything
Old Sep 16, 2008 | 05:59 PM
Formula350's Avatar
Injectors, throttle body, fuel pressure regulator, rockers actually aren't considered internals, cold air intake.
I was going to add turbo/super charger, but even I don't know if that crosses the line or not. NOS as well. They're both bolt ons in all respects of the definition.
Old Sep 16, 2008 | 06:05 PM
about how much hp would that give me all that stuff combined and where should I start? I already have the 160 stat, silencer in the intake blocked off , k&n filter, and straight pipe. this weekend I'LL do the bypass on the tb.
Old Sep 16, 2008 | 06:17 PM
BlackTTC6's Avatar
Headers should be your next mod. The stock exhaust manifolds are a choke point
Old Sep 16, 2008 | 06:59 PM
Formula350's Avatar
Turbo, Charger AND NOS? You'd be making ungodly amounts of power and would need an aftermarket computer
There's already a thread going on right now asking how much power you get with full bolt-ons.
Old Sep 16, 2008 | 08:00 PM
CamaroRacing12's Avatar
full bolt ons are any mods that do not come in contact with engine oil (except rockers)
nitrous or forced induction are def not bolt ons!
Old Sep 16, 2008 | 09:07 PM
Formula350's Avatar
NOS doesn't come in contact with engine oil, it also can bolt on. Or rather, between, the intake and TB. Can even screw in if you want to do it cheaply and put it in your intake elbow.. If you run an external system, nor would a *charger come in contact with the engine's oil. So, that definition is quite flawed.
Old Sep 16, 2008 | 09:10 PM
IronOutlaw's Avatar
I call superchargers and turbos forced induction. But technically i guess they are a bolt on. So i guess a bolton lt1 could make 500 rwhp.
Old Sep 16, 2008 | 09:22 PM
dre2013's Avatar
electric water pump is also a bolton..and i believe a stall is considered bolton too..i could be wrong on the stall tho
Old Sep 16, 2008 | 09:24 PM
Formula350's Avatar
The EWP I would def consider one, a stall I personally would, but who knows heh
TStat and tune are ones as well.
Old Sep 17, 2008 | 09:21 PM
cool thanks. What would be better a th-350 or a 4L60e. and what does a auto/manual valve body do?
Old Sep 18, 2008 | 12:11 AM
IronOutlaw's Avatar
A built 4l60e gets my vote b/c you still get overdrive. A manual valve body means you got to shift manually to the next gear.
Old Sep 18, 2008 | 11:58 AM
robsquikz28's Avatar
check out my thread it will help out all the newbies with bolt on power
Old Sep 19, 2008 | 11:36 AM
goldmecham's Avatar
you can get heads because they "bolt on" jk its not bolt on mod.
