LT1 Pushrods...
Old Sep 20, 2008 | 02:19 PM
Z28Camaro30Ann's Avatar
Default LT1 Pushrods...
Ok, I am upgrading my valvetrain. I am putting in some new valve springs and titanium retainers with a height of 1.800". I am installing GM LS7 lifters and a Comp Cams 503 cam. Do I keep stock length pushrods? I am looking at going chrom-oly on the rods but I dont know what length exactly.....I'm not very educated on valvetrain lol.
Old Sep 20, 2008 | 03:27 PM
Low N Slow's Avatar
You need to set up your valvetrain and measure to get the right length pushrods.
Old Sep 21, 2008 | 03:43 PM
StealthFormula's Avatar
The only real way to know is to use a pushrod length checker and measure the correct length. If your heads haven't ever been milled, deck blocked, etc. etc. chances are 7.200" will be correct. I used the stock length when I had the cc503 and untouched heads, block, etc. Only thing is...I believe the LS7 lifters could throw a length off a tad because I forget exactly but they either have a deeper cup than stock or a little less deeper. Best way to go is to just measure. I would get the Trickflow hardened chromemoly pushrods they seem to be the best.
