blue or white smoke
Edit: pull your spark plugs and let us know what they look like, make sure you mark which one came out of which cylinder as you'll need to know where the problem is exactly.
Valve guides however cannot be replaced with the cylinder heads still on the motor or the valves still in the cylinder heads. Replacing valve guides or putting in guide liners requires machine work. Guides can become worn and get excessive play, causing the valve stem to rock back and forth and let oil by the seal.
