OBD2 to OBD1 swap possible?
I can see not alot is different besides ECU and programming.
Can you just swap out ECU's? i only see minor differences between the OBD1 and OBD2 motors, mainly just the sensors.
any help you would be very appreciated.
94 motor going into a 96 car, and i prefer the OBD1 setup (dont ask)
Thats it...swap that and a tuned PCM and you're good to go. I did the conversion on my car.
We traded shells basically and have the crank position sensor issue now which was just really one car had it one did not... is it a problem what should we do lol.
However this is interesting you mention knock sensors. Since my motor is an OBDII setup going in an OBDI I basically have a few extra sensors like the CPS. Obviously it will not hurt me to not run them. (The ECU does not know to look for them anyway)
HOWEVER, would I be correct to assume I need the OBDI Knock Sensor as my OBDII Knock Sensor is not usable?
Or were you guys talking about the Knock Sensor Chip in the ECU itself?
On another note, any OBDI Ecu he should look for over others?
So it seems pretty obvious that I have to buy a new knock sensor... damn lol. new O2's and a knock sensor.
There is no alterations to the pin outs? its just doesnt read the extra sensor inputs that the OBD2 did? Straight swap in for the computers and its over?
tell me if i'm wrong.
