Turbo lt1 videos
The track passes and some of the videos were with stock heads/cam, but the others were with heads/cam. I never got a clean track pass with the heads/cam setup since I was having a freak wiring problem that I couldn't track down. I need to also find the video of me racing the 580 all wheel HP talon and beating it pretty good from a stop. The car flat LEFT hard on the street on the 315/35/17 dr's when I heated them up.
please send all vids to joey_rodriguez@aztecamilling.com I would like to have these saved to my portable hard drive... That way any conversation comes up I can be like here lets check this out! People around here think my car will not run good with the turbo setup I'm eventually going to get running. And if it does run it will not last.
here's two short ones from me
http://www.youtube.com/watch?v=WzEve0YjH0I
http://www.youtube.com/watch?v=Z3mECDPoY_o
Another two I found, back when I first put it together...
http://media.putfile.com/oct---mid-nov-
http://media.putfile.com/nov-racing
not LT1 but this is the guy I pit with driving his LSX turbo he has been 7.73@196mph without the restrictor plate on the turbo he needs to run in his dragradial class
http://www.youtube.com/watch?v=u_Sg35uzcFw
yep,Andres car is nasty.
#32
Yea, garbage right now, i cant get ahold of tunercats to get my definition file that I paid for, so I cant change my timing. It made 430rwhp on 9psi and 480 on 13psi with 16 degrees of timing on a cam that's about the size of a 306. Needs a lot more tweaking...
#34
385, wiseco pistons, eagle h-beams and crank. Trickflow as-cast heads, bret bauer cam. I think I need to put my second fuel pump in b/c I couldnt get the AFR lower than 12 after 5800, with 75lb injectors.
#40
theres 2 or 3 vids i uploaded on youtube of my buddies Red sts turbo Lt1 t/a..racing a friends h/c/i 5.0 foxbody. just short vids of it untuned, but you get the point. he cracked a ring about 3 wks after the turbo was put on though
