upgrade ya
Old Sep 23, 2008 | 11:37 AM
LT_WON's Avatar
Default upgrade ya
can i expect any horsepower or torque additions with a new msd opti? just a thought .
Old Sep 23, 2008 | 11:44 AM
19mike84's Avatar
maybe if you had issues with the old opti. you can adjust the timing +-7 degrees so thats a plus. i have one and it works great
Old Sep 23, 2008 | 12:02 PM
jarretthise's Avatar
stick with your acdelco unit it will last you soooo much longer than any aftermarket unit... now if your going with anything over 450 rwhp i would go with dynaspark
to be honest you might just be one of the only guys i have ever heard say that about the msd..
Old Sep 23, 2008 | 01:05 PM
fergymoto's Avatar
Doesn't make much sense to rate a distributor by horsepower. RPM if anything
Old Sep 23, 2008 | 01:19 PM
LT_WON's Avatar
Default gm
is the gm performance part the same as the ac delco?? plus wanted a vented unit gm performance opti+msd cap and rotor= more than the price of the MSD opti? decisions decisions. made the mistake of calling the chevy dealership 650 for a new opti wow i call rape.
Old Sep 23, 2008 | 01:20 PM
if your running 450+ then odds are your running your motor well over 5500 rpms at the track...was stating that the acdelco isnt going to hold up and s dynspark is the better of the two if he is going to spend 500 on an opti....if you read his post he asked if it would add hp and i clearly put into words he would understand because obviously he is a newb...these guys work slowly up the pole and we cannot confuse them....i know what im talking about im not dumb....just put things in words he could understand thats all...
Old Sep 23, 2008 | 01:34 PM
LT_WON's Avatar
Default newb on duty
not an expert at all and no claims to be. thats why i asked. merely wanted an opinion on which direction to go. thanks to those who dont use these threads as a pissing contest.
Old Sep 23, 2008 | 01:40 PM
lol might have came off that way but just explaining myself...do have anything to tell us about your motor that can help us pick out what opti would be best?? like specs would be great
Old Sep 23, 2008 | 01:52 PM
fergymoto's Avatar
If your car is a 95-97 here it is for $310
http://store.summitracing.com/partde...5&autoview=sku
If it's a 92-94 $395
Old Sep 23, 2008 | 01:55 PM
LT_WON's Avatar
Default mods
1995 Camaro Z-28 .......no problem somethings are read wrong here are a few mods. not my everyday car drive mainly to the track and back home. But must admit nearly blind when it somes to electrical problems sorry. start at the mouth, 355/LT1 breaths through moroso Cai, granatellli Maf sensor, trickflow elbow, stock TB with foil,port and polished heads, stock 95 cam, march under drive pulleys, Ac delco plat plugs, MSD 8.5wires, Pacesetter Longtubes, no cats, 3 inch true duals X out 2 dynomax bullets before axel. no tune yet........
Old Sep 23, 2008 | 02:09 PM
you should be fine with a delco....those prices seem odd...the vented opits are usually more...go to ebay and look up partsladi....she sells a good opti...alot of ppl are going with her and not ahving probs...its the same as the acdelco just a different brand...its ok to get though...now all_ignition some guys have had probs with, but i bought from them and havent had a problem yet...we will see...look up both of them...dont buy cheap one from all_ignitioin buy the actaul all_ignition one..basically an acdelco opti with a different pickup..acdelco uses a mitsubishi pick up and all_ignition uses theirs which is an exact replica of mitsubishi
Old Sep 23, 2008 | 02:32 PM
fergymoto's Avatar
As far as I have seen over the years the later vented ones have always been cheaper. Other than a Dynaspark or MSD, a genuine Delco/Delphi/GMPP is the only stock type of opti I would run.
Old Sep 23, 2008 | 02:36 PM
partsladi sells the delphi..
Old Sep 23, 2008 | 06:39 PM
Formula350's Avatar
More cars use the vented, than the non, hence the cheaper price.
And as far as saying (not you Fergy) you should get an aftermarket Opti if you're spinning over 5500 is retarded. Stock rev limiter is set @ 5851 (.43 is you want to get **** lol), and many people spin around 6300 on a Delco Opti.
Old Sep 24, 2008 | 12:30 AM
LT_WON's Avatar
left of 3000 lock up stall modified build .. dump the gmp opti? msd for the win?
