Crank pulley removal (97 LT1)
Old 09-25-2008 | 10:09 PM
I8ASaleen's Avatar
Get an MSD one for fairly cheap, but at 158k you're looking at trouble if you don't just replace the whole distributor for a bit more. You can find them for ~$300 maybe less, but it is very cheap insurance not to have to go thru the headache of having the optical sensor fail on you in a few thousand miles.
I have a question for everyone else on a side note. I have the puller that was used in the vid on the crank hub right now trying to coax this thing off and it keeps turning the engine over, should I put it in gear?
Old 09-26-2008 | 01:20 AM
SS RRR's Avatar
Village Troll
Absolutely NOTHING wrong with that cap/rotor. Clean it up and it'll be as good as new and will serve for many miles to come.
Old 09-26-2008 | 01:21 AM
SS RRR's Avatar
Village Troll
Assuming it's a manual, put your car in 5th gear and engage the e-brake and you'll be golden. If it's an auto you'll have to get creative on somehow stopping the engine from turning over.
Old 09-26-2008 | 02:02 AM
I8ASaleen's Avatar
It's a 6.
Old 09-26-2008 | 02:15 AM
LM97Z's Avatar
Thats what i thought too, i've seen some horror ones in my day, i cleaned up the rotor & its nice & gold now, looks great, the cap was barely dirty inside, the car never missed, i just decided to pull it, i've been having an issue in 4th. gear WOT at 5000 with it having a hick-up after taking out the hypertech programmer, but its running the Gran MAF, i'm going back with a stock screened MAF, hopeing that stops it, it never did this with the hypertech installed, so i figured in my extra time, i would remove the Opti & take a look, i'm really shocked how well the cap/rotor held up after that many miles, i'm not too concerned about the opti going out, if it does i'll just replace it, money is so f#ckin tight right now its pitiful , i hope i don't have to sell the car soon, thats how bad it is.
Old 09-26-2008 | 11:10 AM
connexion2005's Avatar
It's a 6.
Like SS RRR said use your 5th gear. I've used 5th and 6th with no issues but yea it will need to be in gear. Auto's need to locate a flywheel holder.
