What 1.6 rockers?
Old Sep 23, 2008 | 11:23 PM
2XR95Z28's Avatar
Default What 1.6 rockers?
Hey iam looking at putting 1.6 rockers on my right now stock internal lt1. These really help on a stock internal motor? what could i expect from them over stock?
What brand would you suggest?
also i heard i need NSA rockers, that true?
would i need new pushrods or anything else besides the rockers?
thanks a bunch!
Old Sep 23, 2008 | 11:45 PM
texas94z's Avatar
Comp cams pro mags are the only way to go.
Old Sep 23, 2008 | 11:58 PM
SS RRR's Avatar
Village Troll
Either the Crane Golds, Pro Mags or even the CC HighTech are all excellent choices.
You may see a few tenths off your ET.
Old Sep 24, 2008 | 12:14 AM
RoAdRaGe912's Avatar
no, you can run SA or NSA
Old Sep 24, 2008 | 12:36 AM
1badzee's Avatar
I have some used Crane 1.6 gold race rockers (SA) with new Crane rocker nuts with polylocks. $260 plus shipping.
Old Sep 24, 2008 | 08:32 AM
2XR95Z28's Avatar
Alright, thanks for all the suggestions, but will i need new pushrods or anything else while replacing the RR's? is it a good idea to get new rocker studs?
Old Sep 24, 2008 | 08:37 AM
Tony Shepherd's Avatar
I agree with this! By far the best bang for the buck. Easy to set, quiet, and reliable.
Old Sep 24, 2008 | 08:49 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Ive ran GMPP 1.6's SA and Comp Cam Pro mag NSA's with out issue. If your running an aggressive cam, with alot of RPM, go NSA pro mags, but essentially they all work fine. If I were run a LTX motor again, a cheap set of Pro Mags would be my cup o' tea!
Old Sep 24, 2008 | 12:18 PM
Mattsz28's Avatar
Running 1.6's on your otherwise stock car basically is like getting more lift from the cam. You might see 10rwhp. I'd say you'll see a tenth or so. I run magnums in my 383. If I was you and you were doing the rockers, you may as well go ahead and replace anything you can 'easily" while your in there. Pushrods cant hurt, studs wouldnt be bad.
Old Sep 24, 2008 | 12:23 PM
koolaid_kid's Avatar
I have the Comp Cams Pro Magnum self-aligning rockers. A full roller rocker, and very nicely made. I got the chromoly pushrods while I was at it, and ARP studs.
Old Sep 24, 2008 | 01:57 PM
2XR95Z28's Avatar
Iam more than likely either going with the Comp or Crane ones. Also iam going to get ARP studs. Would i get stock length pushrods or what?
Old Sep 24, 2008 | 02:03 PM
LS1 SPEED's Avatar
The above rockers will all work as mentioned by some good people. We have had really good luck with Crower 73641-16.
Old Sep 24, 2008 | 02:10 PM
C_Rules's Avatar
I have crane golds self aligning and no complaints here. i hear the scorpions are pretty good and super quiet.
Old Sep 24, 2008 | 03:40 PM
2XR95Z28's Avatar
Thanks so much for all the replies about the rockers, but can anyone answer my question about the pushrods? do i need new ones? can i use stock? if not what length? need hardend?
Old Sep 24, 2008 | 04:21 PM
Well, it is not a need, more of a want. I used stock length (7.20") chromoly. They will lessen flex in the system. If you do change, certainly go hardened or chromoly.
Old Sep 24, 2008 | 06:06 PM
bowtiedad_z28's Avatar
If you go with nsa rockers you will need guide plates and hardened pushrods for the guide plates. I dont see any problem with running stock length push rods if you are not changing out your cam.
Old Sep 24, 2008 | 06:44 PM
lt1-xjs's Avatar
thanks a bunch!
I would recommend a spring change if doing 1.6's. If you are staying with the stock cam go to 1.7's. I ran Promags for 4 years, good rocker. Switched to Scorpion 1.7's netted 10 rwhp over the 1.6 Promag and are less noisey.
Old Sep 25, 2008 | 07:35 AM
Mattsz28's Avatar
With 1.7's you'll probably need new valve covers, or at least clearence the old ones. At least we had to my buddy's bird.
Old Sep 25, 2008 | 09:36 AM
BOLO's Avatar
I recently installed Comp pro mag #1305 nsa 1.6 rockers/guideplates/7/16" rockerstuds. Had problems with the Crane gold race self aligning ones in the higher rpms. So far no issues.
Old Sep 25, 2008 | 03:40 PM
jmoo86's Avatar
i used ss 1.56 comp. definatly had to get new valve covers
