Steam Tube seal rings
Call the local parts stores, I get them for $2 a piece, a few companies make them, the ones I get are by Four Seasons and they are called Sealing Washers. I think the part number is 24355 but I may be off a number.
I bought 14mm oil drain plug sealing washers, white bag from in the back at Advance Auto. $1.29 each. They had them boxed on the floor for $1.89.
I hope these work, I don't want to have to change them after the engine is in the car.
Be sure not to go crazy tight when installing those banjo bolts. Otherwise it will be hell when your trying to break them lose in the car.
Could you link the fittings you used? I'd like to do something like that as I already hate having to deal with these things and I haven't even gotten them off yet.
Awesome! Thanks for that info. I'm trying to get the heads off now and the steam tubes are pissing me off. I'm going to huck them and use this stuff.
I did similar with mine, except I used a tee fitting in the back of one head. The tee fitting had 1/4" npt on one leg and -6an on the other two legs. Then I just connected the two heads together with a short section of -6an hose. From the head with the tee I have the line going directly to the radiator.
Just worked out a bit cheaper than a y-block setup and it definitely flows more water than the stock setup.
