A4-M6 swap
I still have the column sitting at my dad's house. I'll have to go look at it, because I was about to junk it.
There is that black one on the Clutch for the N/S Switch, and the white one on the Clutch is to dis-engage the Cruise when you push it in as well.
I actually had to bypass the N/S Switch with my setup when I installed the LSX Engine cause for some reason it didn't want to start. Something was not working right with the wiring, I couldn't figure it out so I managed to bypass it.
And BTW.. Chris you're ghey..
