Compression Ratio
Old Sep 26, 2008 | 07:22 AM
Mattsz28's Avatar
Default Compression Ratio
Is 11.7:1 too much for Pump gas on an LT1?
Motor's a 383 with cola crank, diamond pistons, dart pro heads ported by Biddy Winward (NHRA Hall of fame engine builder), thats all the basics I suppose.
What do you guys think?
Old Sep 26, 2008 | 07:37 AM
1redta's Avatar
Default re
probaly ok on 93, you need to figure out your dynamic compresion ratio to decide if the motor is capable of running in that compresion ratio Check out kbsilvolite for the calculator. Art
Old Sep 26, 2008 | 07:49 AM
BlackScreaminMachine's Avatar
Internet Mechanic
yea, it seems DCR is more important, statically speaking I ran 11.25 to 1 on a 6" rod, milled heads (beleived 0.030), -16cc dished pistions w/ a LT4 hotcam w/o issue
Old Sep 26, 2008 | 08:14 AM
Stroked96Bowtie's Avatar
http://www.empirenet.com/pkelley2/DynamicCR.html
Great resource on compression and calculator at the bottom of the page. This calculator takes everything including the cam into consideration. I figured compression with this tool and had my machinist do the same, was dead on.
