Answer this please.
Old Oct 1, 2008 | 01:37 PM
94Dailyz28's Avatar
Default Answer this please.
Well i am thinking of overhauling my camaro.
a shop gave me a price range of 4-5000 for engine/trans.
Anyone know a certified reliable shop in southern california i may be able to ask?
The car is a 1994 z28.
Also question number two.
I am aiming for 400-450 rwhp. I want a cam/headers/gmmg exhaust/Heads/K&N Air intake and 3.73's. My car is an A4. Any help is good help. part names/numbers and websites will help.
Old Oct 1, 2008 | 03:16 PM
IllusionalTA's Avatar
Figure 2K for H/C + labor 800 bux or so..
headers are 800, labor shouldn't be bad since the heads would be off... 200 bux
upto 3800.00 bux and you haven't even bought the gmmg and the gears..
Old Oct 1, 2008 | 03:23 PM
lt1z28camaro's Avatar
ported heads, cam, valves, valve springs = $1650 (elliottsportworks.com) (LE2 kit)
injectors = 200-300 (30# or 36#)
headers = 550 (LPP headers and ory)
pushrods, 1.6 roller rockers, lifters = 650ish (summitracing.com)
opti = 321 (summitracing.com)
plugs/wires = depends on what kind/where you buy
k&n cai = 200ish many websites
You'll want a stall with it 3200 or so yank? (not sure on price i'm not an a4 guy so let others chime in there)
3.73's are good gear to go with as auto.
This should help lead you in the right direction..
Old Oct 1, 2008 | 03:38 PM
94Dailyz28's Avatar
Also need a shift kit in it to make it shift smoother and more accurate right?
Old Oct 1, 2008 | 03:40 PM
lot's of that can be done via pcm tuning which wasn't included in my initial estimate
Old Oct 1, 2008 | 03:48 PM
Just reread your OP and it says you in southern california. That probably means you'll have to run mid's I could be mistaken (emission tests)....This also may limit you on your cam selection. Not entirely sure. Another route you may look into is procharger or vortech supercharge it and be done.. Just a thought.
Old Oct 1, 2008 | 04:18 PM
94Dailyz28's Avatar
I can pay someone to pass my smog so i'm not really worried about that. and i'm looking to do this without adding any type of charger. If i were to add anything it would be STS later down the road
Old Oct 2, 2008 | 07:54 AM
DAVE00's Avatar
Check ebay and the pars section here and on Camaroz28.com as you can find most of those parts used and in great shape saving you tons of $$$.
Old Oct 2, 2008 | 08:00 AM
Mattsz28's Avatar
400-450 is a big range. Through an auto, its alot of power. Havent had mine on a dyno yet, but I think I'll fall in the upper end of that range on motor.
My 383 ran me about your budget to build with the dart pro heads all hogged out and diamond pistons (I'm spraying her next season). On top of that your going to need a transmission that is built to live through that kind of power, then in a few months/weeks figure on blowing your read end to ****.
Its an expensive hobby. I would say your power goal could be met by just a H/C package if you were an m6, but through an a4 I think you might come a little short, if you plan on still being able to drive it often enough to make it worth it. I suppose you could put a small shot on her and just prove me wrong through
