how to make cat back pipe wider?
I'd go for the cutting off the bad part and welding on a new piece of 3"
While it might be cost effective, that's only if it works. If it doesn't and he doesn't have a welder (which would suck), he has to bandage it up and drive it to somewhere that'll do the exhaust work heh
The muffler shop has the hydraulic machine that can easily enlarge a pipe for a few bucks.
now i have to just figure out how to get this steering linkage to clear the headers...grrrr
Hell hath frozen.Anyways, I'd almost rather use the pound-in cone shape expander over the finger type. They work fine for removing the clamp indents, sure, but that's only a small surface area needing to be 'enlarged' (see: restored to original size). Making a larger surface area either enlarged or restored-to-round I feel would be a little harder to do w/o breaking the tool (been there, don't that). I just don't think it's worth the time and frustration.
If anything, remove all the exhaust (if you can) and just bring it to the exhaust shop to make round again with their hydraulic setup.
