non self-aligning 1.6 rockers
Old Oct 8, 2008 | 11:07 AM
wickedformula's Avatar
Default non self-aligning 1.6 rockers
Just a quick question for you guys. Im installing 1.6 non self aligning roller rockers. I put new comp cam springs on and retainers. The pushrods are stock. Motor has 140k on it. Now when putting these on with the guide plates will they clear stock valve covers? im thinking not because they barely clear right now after straightening the posts out some.
-where could i get valve covers to clear them that aren't crazy expensive? Also, down the road ill be installing my CC503 cam so im deffinetly going to be changing lifters and pushrods. I just wana get these on for now to see the gains.
Old Oct 8, 2008 | 11:18 AM
whammer33024's Avatar
you can cut the inner supports to make them fit. do a search, theres a site that shows where to cut. this question was asked just last week i believe
Old Oct 8, 2008 | 11:27 AM
96lt1m6's Avatar
trim the stands like this.
http://i187.photobucket.com/albums/x...oject08357.jpg
Old Oct 8, 2008 | 12:18 PM
96slow6's Avatar
How about the obvious guys. You can not use stock pushrods with guide plates. They have to hardened. The rubbing will will wear through the pushrod and produce lots of glitter in your engine.
Old Oct 8, 2008 | 12:35 PM
i did search this subject a lot and didn't come up with anything to answer my questions. ive seen a lot of people saying you need hardened pushrods. thanks for the link on cutting the supports on the valve covers. i was thinking bout doing something like that.
Old Oct 8, 2008 | 10:09 PM
SoxXpupPeT's Avatar
yes you need hardened pushrods when using guideplates. if not your stock push rods even tho i believe there hardened will wear away fairly quickly causing alot of havoc in the engine
Old Oct 8, 2008 | 10:18 PM
94'BLKBRD's Avatar
Why not buy hardened pushrods? cheap insurance right?
Old Oct 8, 2008 | 10:26 PM
96lt1m6's Avatar
with or without guide plates hardened THICK pushrods are a great idea!
Old Oct 9, 2008 | 10:40 AM
definetly buying new pushrods no worries there. was hoping this woulda been a quick couple horsepower but didn't realize they weren't self-aligning ha. well should be all done tuesday or something. just gott wait on the parts. one the cam and everything is done i'll post up a dyno sheet to see the gains. hoping for over 350 at the wheels
Old Oct 9, 2008 | 04:42 PM
BALLSS's Avatar
you do understand that using your stock push rods with guide plates will cause major problems?
Old Oct 9, 2008 | 07:24 PM
Green3spd's Avatar
Have you looked into the LT4 knock module....?
Old Oct 10, 2008 | 08:36 PM
If you read what i said it states that i am ordering new pushrods
Yes i have looked into the lt4 knock module also. Seems like a good way to keep the computer from retarding timing at especially at higher rpm
Old Oct 10, 2008 | 09:13 PM
SoxXpupPeT's Avatar
i installed my LT4 knock module and it made a bit of a difference. only mods right now are mac mid length headers and it idles smoother and at higher RPM seems more stable
Old Oct 13, 2008 | 10:56 AM
hm i might have to invest in an lt4 knock module sooner than expected. everywhere i read i just hear good things so it definetly can't kill. it does seem that my car should be making more power than it does at the higher rpms. we'll see
Old Oct 13, 2008 | 11:39 AM
SoxXpupPeT's Avatar
definitely get one. for headers alone its needed and for 1.6 rockers id have to assume so aswell.
Old Oct 14, 2008 | 08:47 AM
anyone know if machining is required to the heads for guideplates? I really don't want to take the heads off so if anyone can answer that question let me know. and if you can tell me where to get the right guideplates thatd be even better
Old Oct 14, 2008 | 10:56 AM
LT1's Avatar
LT1
Im going to do the same thing you are. I made a list of things ill be ordering from summit ill post it here.
CC503 (224/230 .503/.510 112 LSA) or a different cam not sure yet.
-NSA Pro-Magnum Rockers 7/16" stud (1:6 ratio)
-Arp (Rocker Arm Stud) 7/16"
-Trick Flow guideplates
-Trickflow 5/16 Hardened Chromemoly Pushrods 7.200"
-Beehive Spring or PAC 1218 springs
-Steel Retainers (LT1 for 918 springs)
-Seats
-10 degree Lock (11/32 super lock)
-New Lifter's
Old Oct 15, 2008 | 08:58 AM
buddy at a machine shop said theres a possibility that the heads will need some machining to get the guideplates to work right. just looking for an answer from someone who already has had NSA rocker put on their car.
Hopefully i wont be selling these for self aligning rockers...
Old Oct 20, 2008 | 10:24 AM
alright got my guideplates and hardened comp pushrods.. we'll see how this goes.
