ls1 driveshaft?
Old Oct 8, 2008 | 05:20 PM
TravisMcGill2000's Avatar
Default ls1 driveshaft?
how much gain do u c with a ls1 driveshaft over stock. rwhp and e.t and the weight difference. thanks guys
Old Oct 8, 2008 | 05:26 PM
connexion2005's Avatar
I wouldn't think you could see to much on et or rwhp but weight wise I would say around 20lbs of rotating mass but please don't quote me since I have only held each one in my hand and never wayed. The key advantage to the swap is the weight reduction and it gets rid of the annoying vibes everyone experiences at 100+mph...
Old Oct 8, 2008 | 05:38 PM
PNYKLR-TA's Avatar
i thought that was the only gain at first but i guess dude is right, if rotational mass is decreased, then weight is lost and therefor should yield some gains in the ET side of things, only because of lost weight, i wouldnt see how it would gain any rwhp being it is only lighter, and does not release more power.
and also i was told by an older man who used to race quiet a bit in his younger days that every pound of rotational mass is equal to something like 5 or 10 pounds of dead weight. correct me please so i can remember the correct number this time.
Old Oct 8, 2008 | 05:49 PM
StealthFormula's Avatar
An LS1 driveshaft is about 5 or 6 pounds or so lighter than stock Lt1 steel. Being that the body of it is so skinny (3 or 3.5in. I do not recall) the typical 1 pound=~10 pounds rotational mass does not really apply unlike it would for a larger diameter flywheel in which it would definetly apply. Essentially the car is losing about 5lbs. overall and freeing up 1-3hp. Although it wont show any gains at the track I feel for $100 its worth using not only for a little bit of weight reduction but for smoothness over the stock driveshaft at highway speeds.
Old Oct 8, 2008 | 05:58 PM
James Montigny's Avatar
http://www.ws6.com/mod-1.htm
It's all about the faster acceleration, not peak HP increases.
The reduction in rotating mass had a pretty significant effect on the torque curve down low
Old Oct 8, 2008 | 08:57 PM
grossesexy's Avatar
Incredibly useful dyno graph there James, thanks for posting that.
Old Oct 8, 2008 | 09:15 PM
AChotrod's Avatar
I tested it. I didnt gain any MPH at the track. Although it was 2 different days.
I did run better the second time but it was in the 60ft. MPH was basically the same
Old Oct 8, 2008 | 09:21 PM
kinglt-1's Avatar
I think the main goal is to get rid of the annoying vibration the stock unit causes above 80mph. No one really looks at the gains to be had, good dyno graph tho. Makes sense on the tq gains, since the ls1 shaft spins easier.
Old Oct 8, 2008 | 09:24 PM
AChotrod's Avatar
Vibrations are gone and it felt a ton lighter, but at the track it wasnt noticable. The car used to vibrate real bad anywhere past 80-90mph, now its smooth as silk no matter how fast i go. totally worth it even if it doesnt help at the track. On a dyno maybe?
Old Oct 8, 2008 | 09:44 PM
k thanks alot guys worth a 100 bucks 2 me
Old Oct 9, 2008 | 08:51 AM
PNYKLR-TA's Avatar
thats what i thought, and i thought the rotational mass rule applied to anything being spun by the motor not just the flywheel, i mean just think about it in lamest terms, like a heavier rim, or drive shaft, its like when youre at the gym next time try this, put some 45lber's on the olympic bar and rotate the bar in your hands, now put 10's on and rotate the bar, you can get it spinning much faster in a shorter amount of time with the 10's becuase it weights less. so wouldnt the rotational mass theory typically apply here?
Old Oct 9, 2008 | 08:57 AM
CamaroRacing12's Avatar
yes it does,an ls1 driveshaft is a good and easy mod...
Old Oct 9, 2008 | 10:46 AM
rotational mass will apply to anything moving, wheels, flywheel, driveshaft etc. but it wont apply as much to a 3in. driveshaft as it will to say wheels. Unlike wheels or a flywheel, driveshafts don't have the diameter to have much effect on reducing rotational inertia (reducing the motor's effort to spin up the shaft) so the weight savings is mostly in how much lighter the new ds is to the stock ds.
Old Oct 9, 2008 | 11:13 AM
PNYKLR-TA's Avatar
i see where your coming from as the diameter would affect it more along with the weight difference, but still the weight difference helps alot, i'd say taking 3lbs off of drive shaft has to equal at least taking 10lbs out of your car of dead weight.
but all very good valid points, and really the shaft is for less vibration cause if you were looking to shed some weight you could buy an expensive *** carbon fiber drive shaft or something.
Old Oct 9, 2008 | 11:40 AM
the_merv's Avatar
Veteran: Air Force
I weighed it at 12lbs, the stock one at 30ish.. there is more than a 5lb difference between the two.. easily..
Old Oct 9, 2008 | 11:52 AM
PNYKLR-TA's Avatar
DAMN WELL THEN 18LBS, I WAS JUST GOING BY WHAT SOMEONE HAD POSTED, SO I'D SAY 18LBS OR ROTATIONAL MASS FOR THE DRIVE SHAFT CONSIDERING ITS 3" HAS GOT TO BE CLOSE TO 50LBS OF DEAD WEIGHT.
Old Oct 9, 2008 | 01:40 PM
the_merv's Avatar
Veteran: Air Force
Don't quote me on that either..that's roughly what they weighed on a digital scale. I'm just saying that there is easily more than a 5lb difference between the two..
Old Oct 9, 2008 | 01:54 PM
camaro-94-z28's Avatar
where do you guys buy these driveshafts for 100$?
Old Oct 9, 2008 | 02:01 PM
the_merv's Avatar
Veteran: Air Force
Classifieds..Ebay.. keep your eye's out..they are around.
Old Oct 9, 2008 | 02:04 PM
jarretthise's Avatar
this is pretty good useful information...i liked reading this thread
post up in the wanted section or go to the local junkyard and just ask for ls1 alum driveshaft...easiest way to get one...now you could go buy an aftermarket one for around 300+ if you have the money to blow
