Clutch disc still good?
Well first you would need to know how thick the disc was from the manufacturer. Then they could also tell you how much wear you can expect, usually around .030-.040". Use a set of mics to determine if you have life left on the disc. I would say after 70,000 miles the disc is probobly shot. Also better to replace while you have it out anyway.
Yeah I got the replacement right here.
https://ls1tech.com/forums/manual-transmission/1003534-stock-vs-hypersingle-weights.html
