need help
well i think my clutch went out but not sure if it is...i was on the highway the otherday an i was getting ready to pass up a car an then all of a sudden i was jus revving like if my clutch went out..i parked it an got it tolled back to my house..i havent had a chance to take it anywere to get it check but the thing is that im able to turn it on..b4 i start it the clutch goes in good like its not loose it feels hard well how it useally feels an the car turns on..an while the car is running i can put it into all the gears an all it does is jus rev..wont go nowhere..i have to use the clutch to put into first but 2 an the others they go on there own...i really dont much bout clutches so if anybody can help or any advice of what they think it is i would it would help me alot..thanks guys!
Sounds like your clutch is worn out and is slipping.
Also, are you saying you are floating the gears? From what I know, that's none too good on your synchros... It's a lot easier to change a clutch than it is to tear into the internals of your transmission to change the synchros.
well i bought it from the ws6 store i havent really looked into it...im wanna say about a yr in a half to about a yr....an not really i would jus drive it reg well at least i think..
