Spec stage 3 clutch is squealing still!!! Help!!!!
Without boring details, we put my spec st 3 ceramic clutch back in to exact torque specs and since then ( a few thousand miles ago) it squeals every time it's engaged (during clutch take up)- does it on upshifts and downshifts. Any ideas? I was wondering if it could be the bushing that you slide the trans input shaft in to. Just a swag.
Re: Spec stage 3 clutch is squealing still!!! Help!!!!
Aggressive clutch materials will do this especially during break in. I've heard that the ceramic is notorious for it. Try being aggressive with the clutch engagement several times to see if you can get any possible glazing stripped off.
