estimated cost for a clutch swap
If you do the work yourself then you should be able to pull it off for around $350.
I did it on my old 97 SS, got a RAM HD clutch for 325 shipped, did the work myself and after all said and done...... $350.
My labor price was $400 from a shop in NYC. Normally it would be a bit more, around 450-500, but I know the owner somewhat. The labor books normally say 6-8hours so it depends on how much the shop will charge you per hour. Southern state labor is USUALLY cheaper.
